Short flying distance
239 1 2022-8-26
wbd
Flight distance : 277037 ft
last few times out flying the distance was quit short with the mavic air 2, What is the range for the mavic air 2. I also have a mavic air 2s and have no problems flying 3 times farther than the mavic air 2 in the same location and flight path. Is there that much of a difference between the 2 drones as far as range?
2022-8-26
DJI Stephen
Hello there wbd. I am sorry for the trouble this has caused and thank you for reaching out. May we please know if the firmware of your DJI Mavic Air 2 is on its latest one and may we please know what is the model of the mobile device that you are using please. In addition, kindly please fly your DJI Mavic Air 2 to a different location with less interference to see if the issue will still persist? The DJI Mavic Air 2 might have picked up magnetic interference on the ground, and you took off from close to a buildings with rebar concrete metal objects on it. In addition, please make sure that the antennas are pointed toward the aircraft for optimal transmission. Thank you.
2022-8-26
