upgrade phantom 1 to 4.0.2 on Mac problem
1539 6 2014-12-2
walteranker
Hi,
I am trying to calibrate my Phantom 1 which currently has firmwar 3.14 but I need to install 4.0.2 according to the Naza M assist V2. The intruction says you have to adjuste the  'Default Configuration Parameters' but this is only available for Windows it looks like and I am using a Mac.
Is there a way around this?
Can I configure it manually?
Is there a way to calibrate my Phantom 1 without having to upgrade?
Any help is greatly appreciated.
Regards,
Walter
2014-12-2
walteranker
DJI service person around maybe?
Kind of stuck here with what appears to be a half cross-platform solution by DJI. Getting the default config settings to put them in manually is fine.
Should I upgrade or if not how do I calibrate the drone using the current version?
Thanks
2014-12-3
jamesnns
Find a friend with a PC...?
2014-12-3
Rodimus Prime
China
Hi walteranker,
Would you be able to fly the Phantom 1 without this default configuration? You mentioned keying in the config settings manually is fine.
2014-12-7
walteranker
Rodimus Prime Posted at 2014-12-8 09:11
Hi walteranker,
Would you be able to fly the Phantom 1 without this default configuration? You ment ...
Hi,
I have not done the firmware upgrade yet and tried it out as I am worried it won't fly well and crash.
2014-12-11
jamesnns
Seriously.  find a friend with a PC and do it from there.  I HIGHLY doubt there's going to be another firmware update after Ver. 4.02.
Dont forget to do an advanced IMU calibration (ignore "hot" warning)and make sure IOC is enabled and the S1(c) switch is set to Failsafe.
After that, theres really no reson to use Naza Asst again unless you need to cal the IMU again
2014-12-11
walteranker
Thanks James. I did the calibration on a friends Windows machine. The Phantom works now, but the Zenmuse H3-2D gimbal is stuck in a downwards position. Next problem to try to tackle.
2014-12-14
