No Camera View on Mobile
963 6 2022-8-27
fprandi
Brazil
I downloaded the DJI GO4 app from the DJI website, and the drone flies fine, but there is no camera feed to my phone. The camera is definitely working, as I can view saved video and images on the app. Having looked online for solutions, it seems I'm not alone in having this issue. How do I resolve it, please? Using Samsung S21 - Mavic 2 Pro
2022-8-27
DJI Stephen
Hello there fprandi. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to uninstall and reinstall the DJI Go 4 ( https://www.dji.com/downloads/djiapp/dji-go-4 ) application to see if the issue will still persist? In addition, please sync all of your flight records before uninstalling the DJI Go 4 application on your mobile device for you not to loose your previous flight information. If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the said issue. Thank you.
2022-8-27
fprandi
Brazil
DJI Stephen Posted at 8-27 20:34
[view_image]
did not work, had already installed this same file.
2022-8-30
cosminc1971
Hello
Do you have any solution for this issue?
Thanks
2023-6-15
DJI Paladin
Flight distance : 318 ft
cosminc1971 Posted at 6-15 02:47
Hello
Thanks
Hi there. Thank you for reaching out. Can you please confirm what specific issue did you experience on your unit? Please provide us a detailed inquiry including the DJI product that you are using so we can help you further. Please keep us posted.
2023-6-24
fansf891cc1e
Indonesia
I have the same issue, I had mavic 2 pro with dji go 4 installed on my s21 fe, everytime i uses the app it gives me grey screen while the camera is fine, Funny thing is it works fine on iphone, the camera showed up perfectly fine but not on my s21 fe
2-19 07:50
DJI Tony
fansf891cc1e Posted at 2-19 07:50
Hi there. We are more than glad to help. Will it be fine if you post a screenshot showing the said issue/ Thank you.
2-20 00:47
