tioe
Flight distance : 144649 ft
Dirty Bird Posted at 8-27 19:14
Not discounting the usefulness of Course Lock, but why couldn't you achieve the same thing using Spotlight or flying manually?
I thought too that spotlight would allow this to be accomplished, but it seems not. Yes I can fly a big arc around a subject and keep it in frame, but that's not exactly what course lock can do.
Here's an example of the path my other drone took in that lighthouse shot (@2:20), and how course lock could be used to achieve it. (My other drone flew in a straight line on the same course, only the gimbal rotated).
As far as spotlight goes, it seems that I need to fly a wide arc around an object to keep it in frame. The whole point here is that I want to fly a straight line, not an arc.
As far as flying manual, I don't think it would be possible to rotate the Mini Pro 3 on it's own axis while flying in a straight line .
If the Mini Pro 3 could record video in course lock mode then it would allow flying close to objects and rotating the camera as it flew past as though the camera were on a rotating gimbal.
If there is a trick that I'm missing I'd love to know.
