Sean-bumble-bee
Flight distance : 15997 ft
With regards to height, why not ask the maker of the video, it would avoid speculation.
With regards to stopping the motors in mid air. As JJB has said, the CSC response needs to be set to "Anytime" / "Always" for this to happen, if the setting is left at the default the drone will most likely NOT stop its motors. Tested from height down to around 1m with a Mavic Mini. If the setting is changed to "Anytime" / "Always" the motors will stop after the CSC has been held for around 1.7 seconds.
With regards to restarting the motors, a separate CSC is required to try to restart the motors, i.e. if you continue to hold the motor-stopping-CSC no attempt will be made to restart the motors, tested with a hand held and wobbled Mavic Mini, possibly a M2P/Z and perhaps a Mini 2.
An 'in actual flight' motor stop and restart has been attempted with either a Mavic Mini or a Mini 2 but, from memory, the pilot did release the motor stopping CSC and the drone crashed, from 1000+ft.
If the drone tumbles then the restarting CSC would need to be held for whatever time is necessary for the drone to move into the 'acceptable angle of tilt' zone, outside that zone the motors will not restart, again tested with a hand held and wobbled Mavic Mini etc. etc..
Even then I do not know if a Mini type drone, with freely pivoting propeller blades, will be within the 'acceptable tilt zone' for 'long enough' to restart the motors in mid air.
Finally, it may be necessary to give the drone considerable throttle to halt the fall, it depends on whether or not the Mavic type drones are 'clever enough' to 'realise' they are still falling, a Phantom 3 is not and the motors restart at idle and remain there until given throttle.
