Mini 3 Pro prop + RC - Screw size, types and dimensions.
12203 16 2022-8-31
RoZis
Flight distance : 1754314 ft
As mentioned in the title I would like to know the types of screws for the Mini 3 Pro and RC Controller
- Propeller  (male thread)
- RC Controller Sticks (female thread)
Is there any official list available?
2022-8-31
Goggles Pisano
Flight distance : 8810745 ft
I don't think you will find any official list available, Probably have to remove one and figure out for yourself...
2022-8-31
fans5d3e3440
Flight distance : 4964 ft
And don't forget that the propeller screws have a step in them.
2022-8-31
RoZis
I don't want to use any other screws.
The originals are treated with microencapsulated adhesive (threadlocker)
I am only concerned about the thread types ;)
2022-8-31
RoZis
So far, what I know
First look says M1.2, but it is M1.4 because trapezoidal thread
Thread pitch:0.25mm
Thread diameter: M1.4 (1.2mm, trapezoidal)
Thread angle: 60°.
Screw length: 3mm
Head: 4.15mm x 0.65mm
2022-9-29
DJI MacFly
Flight distance : 150758 ft
Has anyone seen torque values for tightening these screws (while fastening the propeller blade)?
2023-3-8
RoZis
No, I haven´t found anything official about the DJI Mini 3 screws.
Non-binding and at your own risk, I would assume this tightening torque
0,15 - 0,20 Nm / 15 - 20 Ncm (only for new screws)
But, the max. possible tightening torques here, e.g. 15cNm to M1.8, do not fit logically
https://sewa-werkzeuge.com/files ... schraubendreher.pdf
However, tightening torques for such small screws are almost impossible to maintain precisely.
It is much more important that the screw is completely screwed in and ALWAYS use new screws (never already used) to ensure the full function of the screw lock (blue pre-coating), even tightening torque is less.
At my place we say "Nach fest kommt ab"
2023-3-8
Aurgelme
Flight distance : 2730 ft
Norway
RoZis Posted at 3-8 11:17
That was strange. Received new drone few weeks ago with fly more package and two spare sets of propellers. None of the screws are pre-coated with blue screw locking. There was also no screw lock on the propeller screws that were factory mounted on the m3p drone
2023-3-8
RoZis
Aurgelme Posted at 3-8 12:09
Possibly the damage to the screws when loosened by customers outweigh the drone crashes due to missing propellers because screws come loose?
But, I received my spare set in 2022-12 and here in sealed bag, you can see the pre-coating ;)
2023-3-8
djiuser_YytZaRH64SLf
Hello, is it possible to find the same Torx or Hex head screws? I hate the PH head because I keep messing up the screws. By the way, a small paper manual with the required torque of 1.2 kgf.cm is attached to the original DJI replacement propellers. I tried to achieve this with a precision torque screwdriver and it didn't work - the screw was broken and had to be replaced.
2023-4-18
RoZis
djiuser_YytZaRH64SLf Posted at 4-18 08:00
I can hardly imagine that.
My smallest torque screwdriver starts at 40cNM (40N/cm) which should be about 4.07kgf/cm.
That's less than I use for tightening.
Can you please take a picture of that small manual please?
EDIT: Thankyou for updating with correct torque 0,118Nm / 1.2kgf.cm
https://forum.dji.com/forum.php? ... 278&pid=3057913
2023-4-18
MRDroneRookie
Flight distance : 2680259 ft
RoZis Posted at 4-18 09:53
Myself I turn the screws in until they bottom out and do not tighten any further. I think any tightening on these tiny screws risks snapping them off. With the thread locker on them I do not feel there is any risk of them backing out. The top of the screw head is flush with the plastic hub of the propeller when it is screwed in all the way making it quick and easy to do a visual check during preflight inspection to make sure none of the  screws are backing out.
2023-4-18
RoZis
MRDroneRookie Posted at 4-18 11:14
You are right....
...not necessary to tighten the screws until water comes ;)
Because my eyes are failing and I am impatient, fine paint strokes help to quickly check the still secure fit of the screws.
2023-4-18
MRDroneRookie
RoZis Posted at 4-18 12:03
You are right....
That's a great idea. I am going to start doing that right now.
2023-4-18
Skarl
Flight distance : 4790 ft
Goggles Pisano Posted at 2022-8-31 14:54
Lost my Mavic 2 Zoom.  Bought a rebuilt dji mini 3 pro.  Screws for propellers were incorrect.  Ordered replacements from Amazon.  Then I am in trial with a lovely court reporter.
2023-5-10
Page from the spare props manual.
From spare props manual
2023-6-1
SunDune
Flight distance : 64491 ft
RoZis Posted at 2022-9-29 12:38
So far, what I know
[view_image]
The most useful comment that comes on a thread.
2024-2-23
