Avata Battery Charging is slow [SOLVED]
11061 19 2022-8-31
Bob Brown
Flight distance : 4209662 ft
Not sure is it supposed to take over 4-5 hours to charge a single battery. Is this the norm? I am using the included battery charger and a DJI FC150 50W USB charge port. (high speed usb charging) Compared to my Mavic and Mini drones this seems to take forever to charge.  At this rate I will get to fly for 45 minutes every few days with the 3 batteries I have. (13-15 hours to charge them all)
Any way to charge them faster without damaging them?
2022-8-31
KlooGee
Flight distance : 16783757 ft
According to DJI batteries should charge in about 47 minutes with a 65W charging block. My experience is very similar.
2022-8-31
Lucas626
Flight distance : 50642090 ft
I used my M3pro charger and the lights started lighting fast and charged faster.
2022-8-31
DJI Stephen
Hello there Bob Brown. Thank you for reaching out and for giving out these information. Kindly please try using a different recommended charger ( 65W Portable Charger ) to charge your DJI Avata Intelligent Flight Battery for us to be able to isolate the issue. The DJI Avata Intelligent Flight Battery's Charging Time ( for one single battery ) : When charging it to 94%: It takes approx. 37 mins., when charging it to 100%: It takes approx. 48 mins. Thank you.
2022-8-31
Bob Brown
DJI Stephen Posted at 8-31 19:02
Where do I get this 65W recommended charger in the USA? Been out of stock for a while now.
Inquiries via chat just tell me to request notification... not helpful. Amazon and other vendors are dry.
Any idea when this and the FPV Controller 2 are back in stock?
Update... I fianlly found some on Amazon! (was dry yesterday so maybe inventory is coming back?)
https://www.amazon.com/gp/product/B09J81VQW2
Thanks all for your help... glad I asked and not sure why DJI does not include the charger in the combos. Seems like it is required for use.
2022-9-1
JakeWest
I’ve been using a 65w Anker nano and anker usb c to c I use to charge everything else.  No problems charging the Avata battery in under an hour with the stock adapter.
2022-9-1
Bob Brown
JakeWest Posted at 9-1 06:47
Yeah but with DJI Support using anything other than DJI gear will cause support dismissal syndrome.
I appreciate all the advice and glad there is a better way.
2022-9-1
JakeWest
Bob Brown Posted at 9-1 07:04
Like I get that but before I even went to this they were not very helpful in trying to resolve my issues so…. Lol that works… also needed what seems to be a pretty specific cable to even get the fpv controller updated on pc (cough GoPros oem usb A to C).
2022-9-1
KLRSKIR
Flight distance : 28368625 ft
I have a few of these and a few of these around the house, both are GaN and both work great wilh all of my devices.
2022-9-1
djiuser_tb0AVKwqEhuj
Denmark
I have the same problem.
Tryed 4 different 65 fast plugs....fast charger...6 cabels 2 fast cabels. , still 12 hours for 3 batteries.
Now i have to send them to dji , an what 14 days for new batteris. Nice service on a brand new drone
2022-9-7
Scatamonky
Flight distance : 39 ft
I'm in the UK - came here for the same reason - tried the fastest Samsung fast charger took over 4 hours - then tried a Nintendo Switch charger - still took over 4 hours. I'm looking at a 108W charger on Amazon for £26 - reviews all seem good too.
https://www.amazon.co.uk/108W-Mac-Book-Air-Charger-Black/dp/B09YL5JB91/ref=sr_1_10?keywords=100w%2Busb%2Bc%2Bcharger&qid=1662556937&sr=8-10&th=1
2022-9-7
Bob Brown
Scatamonky Posted at 9-7 05:27
To avoid any issues I would highly recommend the DJI 65W charger. I got one and charging is super fast now... charges all 3 batteries in less than 2 hours now with the Avata Charging hub. That one looks a bit over powered and may damage the batteries? not 100% sure... may damage the charging block first.
2022-9-7
KLRSKIR
Bob Brown Posted at 9-7 06:21
The charging hub/batteries will only allow what the batteries need. Thus "Intelligent Batteries."
2022-9-7
Your Friend
Flight distance : 1757375 ft
I think a MacBook charger would work perfectly.
2022-9-7
SkySight Aerial Perspective
Flight distance : 3312018 ft
Your Friend Posted at 9-7 06:56
This works fine as long as you use the lower type c port.
https://www.amazon.co.uk/gp/prod ... 0?ie=UTF8&psc=1
2022-9-10
djiuser_hMn4RAkirLth
What charging block specifically? I’m a little shocked that DJI pushed these things out without ample battery (or controllers) options available. I guess I need to charge this thing as fast as possible… because I have 1 battery and can only use it for 10 minutes every 5 hours or so….. MASSIVELY disappointing. Experience debilitating
2022-10-29
2022-10-29
fans5bb87d54
Flight distance : 1176509 ft
Slovenia
I have perfect and cheapest solution for fast charge DJI Avata and Mini 3 Pro! Buy any 100w car charger and use original short USB C to USB C cable from pack of DJI Avata or Mini 3 Pro.
Problem solved! Now you can fast charge your drone
2023-1-7
Chris Brown2
I had the same issue until I removed the usb C "adapter" from the arrangement. 65w port usb C to the usb C charging hub. Then it worked fine
3-14 06:16
djiuser_pcpivuxk7q0G
Flight distance : 427720 ft
Lucas626 Posted at 2022-8-31 18:44
Thanks bro this is a hack!
4-13 13:51
