Manual mode limited
8613 14 2022-9-1
JAMh
Flight distance : 4754715 ft
Hi
Just tested my new AVATA in MANUAL MODE with the controller but found this:
- Still stabilized. I thought it will ´fall down´ if i cut off throttle, but it remains at same altitude like in Normal or Sport mode (left stick without spring)
- Speed limit. It's slower than in Sport mode.
- Angle limits: Unable to do loopings in any direction. Less than 30 degrees aprox of angle limit.
Sure I'm doing something wrong.
But the Drone gets in Manual mode, the camera angle changes to 14deg aprox (like a normal FPV drone) and I see a M in the screen :-). Also enable and disable the Limit in the controller ROLL/YAW/PITCH RATES screen (sorry I don´t remember the item name).
Can anyone tell me what i´m doing wrong?
THANKS IN ADVANCE
In the meantime, really surprised with the Joystick (Motion Controller). Really easy and intuitive. And lets you do things really complicated for normal FPVs drones (more than 3 years of experience/crash/repairing)
2022-9-1
alex_markov
Flight distance : 39646480 ft
Bulgaria
You missed a tick in the menus of goggles allowing loops - Just refer to manuals
2022-9-2
JAMh
alex_markov Posted at 9-2 09:57
THANKSSSSSS
Sorry, but where is this button?
I havent seen it on the manuals
2022-9-2
Buzzyone
Flight distance : 4647913 ft
JAMh Posted at 9-2 10:27
THANKSSSSSS
In the goggles, under Control, select remote control, Gain & Exp. There is a switch that removes the roll limit.
Only available with the FPV Remote 2. Once that switch is turned off, you will be able to roll and loop.
2022-9-2
JAMh
Buzzyone Posted at 9-2 10:43
I did it.
Tested with this ON and OFF...
Will try again
Of course it's with the remote control, because with the joystick u dont have this option
THX
2022-9-2
fredbotton75
Flight distance : 1832001 ft
Try again, it does indeed remove the roll & loop protection.
2022-9-2
Buzzyone
You also need to change the Custom Button (switch) to Manual as it’s default isn’t that!
Once you have done this and turned off the roll limit, when switching the switch to Manual you should see two squares in the goggles, you have to set the sticks to the green marks and then the drone will go into full manual mode.
2022-9-3
djiuser_M9Y9jMBVs6JL
I dondt see the option for the flips.
Custom button is set to manual.
he first time i set it to manual te 2 check boxes apeared and after set the stick to the green, they never show up anymore
2022-9-3
Buzzyone
djiuser_M9Y9jMBVs6JL Posted at 9-3 01:36
[view_image]
You have the M Mode Attitude Limit set correctly, have you set the Custom Mode to Manual too?
2022-9-3
Buzzyone Posted at 9-3 01:50
[view_image]
yes i did set it up to manual
2022-9-3
Buzzyone
I would probably do a reset and have another go, it does work, was doing loops and flips yesterday.
Reset the goggles and the remote options and try again.
2022-9-3
derono
can share screenshot of that option?
2022-9-3
djiuser_Fwn3wKqS6Xnf
Algeria
Quelle est la porter ou bien la distance de vol Maximal du avata
2022-9-28
JAMh
Mexico
THX
Finally the last firmware update fixed it.
It was strange as I did everything all of u said.
THANKS 2 ALL
PD:
If anyone wants to check my videos:
Here in Spain:
https://forum.dji.com/forum.php?mod=viewthread&tid=273742
https://forum.dji.com/forum.php?mod=viewthread&tid=274158
And here at Caribbean sea:
https://forum.dji.com/forum.php?mod=viewthread&tid=275046
2022-9-29
ro_walker
Brazil
Flying manual on restricted zones is not possible....
2023-4-1
