Mat8861
Flight distance : 169400 ft
Hi DJI Stephen, is a bit difficult to replicate i should downgrade and re-do firmware update. Basically what happened , i started (see photo) during firmware update the drone restarted and propeller did a small turn clockwise and counterclockwise getting blocked by the USB plug, luckly it was a small turn. I really didn't try to remove the usb cap as i see is attached with a tiny piece of plastic. Anyway as you can see it's not the best option, next time i will remove the propeller to have more space .I also bought an USB adapter with 90 degree elbow, may be that will help a little getting avata connected when there is the need to, although i would prefere that everything should be possible via wifi. Thanks for your attention.
