Mini 3 pro engine failure ? Crash...
2667 22 2022-9-3
djiuser_6KgmBiNgX3Gd
Flight distance : 54327 ft
Belgium
Hello, i was planning making a great view of the beach today but everything goes bad.... 30 seconds after take-off, my drone decide to increase its altitude alone.... I decided to abord the fly because i thing there is something wrong with it but it was too late. One of the rotor stop working and Boum.....
I've uploaded the flight log to the cloud with the remote controler.
I've uploaded also the video on youtube if needed
Is it normal that just after few hours this beautiful drone stop working like this ?......
Thank you very much for you support....
2022-9-3
DowntownRDB
Flight distance : ****
If you want to learn what your flight data tells of your incident ...
To get to your flight data, go to: https://www.phantomhelp.com/LogViewer/Upload/
... where you'll find instructions to upload the data to that site and it will give a report
For help interpreting the data you can post a link for the report here.
Or just post the .txt file.
2022-9-3
Gi-manuel
Belgium
Hello, thank you for your reply but i try to download the data from the mini 3 pro and the RC but the log was uploaded to the cloud and impossible to retrieve them inside the storage.
2022-9-3
DJI Susan
I am sorry to read about the mishap, that must be frustrating. As the drone crashed, kindly send it in for further diagnosis and service.
Please fill out the online repair request on our official web and send the drone back.
Please remember to tick "Apply for data analysis" when filling in the info, data analysis can be processed as long as the drone is within the warranty period and the corresponding offer will be provided based on the analysis result.
2022-9-3
Bashy
Flight distance : 2354357 ft
The files should be on the controller's (screened) memory card or your phone if using the N1
It looks to me like it may have hit a bird  or blew a prop, wont know without the flightlog, ya need to get hold of that
2022-9-3
Labroides
Flight distance : 26781877 ft
Gi-manuel Posted at 9-3 11:49
The .txt file will still be on the phone/tablet that you flew with.
2022-9-3
DAFlys
If you setup a free airdata.com account it can sync you logs from DJI and let you download it again
2022-9-3
JJB*
Flight distance : 13955751 ft
looks like it hit a wire.....
stop video at 9 secs, see a thin wire top on 4th car for the left to the right.
Another wire probably just above this one and bit closer to the drone. (often come in pairs)
2022-9-4
Hannibal_
Flight distance : 297126 ft
Gee… now that was a sudden hit.
Hope it gets resolved somehow.
2022-9-4
SuperWinnieperruna
Flight distance : 542083 ft
Si yo no veo mal delante del drone hay poste de luz con líneas de alta tensión ,, hay dos opciones , o has rozado una de ellas (lo más seguro ya que no va una línea sólo sino van varias a diferentes alturas) o por motivos eléctricos ha influido en el vuelo , ya ellos lo avisan que éste tipo de campos influye en el vuelo ,también tienes que tener en cuenta que al volar sobre barrancos y callejones los drones tienden a subir debido a corrientes de viento ... lo bueno de todo es que lo has poddo coger en el risco así que si tienes plan de reemplazo se lo puedes enviar ... saludos desde LPA
2022-9-4
Gi-manuel
Belgium
Wires was at 20m of the drone.
2022-9-4
Gi-manuel
Belgium
Look at the pictures there where no wires... When the engine stop, the drone was above in the void.
2022-9-4
Gi-manuel
Belgium
JJB* Posted at 9-4 00:15
If you see the wire on the video it's because i'm higher than it, wires was top of me so if you see me and the wires it's  impossible.
2022-9-4
Gi-manuel
Belgium
2022-9-4
Gi-manuel
Belgium
I try the app that you mention for the log informations.
Has you can see the white line is the powerline.
Where the battery icon is : where the drone engine stop suddenly.
Point K where i retrieve the drone crashed.
2022-9-4
JJB*
Gi-manuel Posted at 9-4 02:48
oke,
if you like use this  > https://www.phantomhelp.com/LogViewer/Upload/
Post the uploaded link on here, explain bettter than airdata
cheers
JJB
2022-9-4
Labroides
Gi-manuel Posted at 9-4 03:25
If you hit a wire, the recorded flight data will show that.
But those screenshots from Airdata are no help.
Post a link to the Airdata report, but make sure that you tick the share box.
2022-9-4
Gi-manuel
Belgium
Heres the link.
https://app.airdata.com/share/TCXpwZ
I say again, the wire was 20m far away of the drone when it crash....
2022-9-4
TonyPHX
Flight distance : 12142077 ft
I still suspect the wire.
2022-9-4
Gi-manuel
Belgium
TonyPHX Posted at 9-4 06:04
If you have me, the ground, the wire on the same record it's because i'm far away.... The mini 3 pro didn't have a Focal of 180 degres.
Wires are at 6m maximum higher. The drone was more thank 15m higher above the take off position and more than 10m far away of it.
I take a screenshot in the video when it crashed. You can see that i've a view of the small powerline, the road, the hill... If i was touching the cable it should be impossible to have all these details....
2022-9-4
Pleomax
Flight distance : 835725 ft
Gi-manuel Posted at 9-4 07:36
Sorry for your loss.
Had a look at your flight log looks like you were  using Mode 1.
AC was gaining altitude without elevator input.
Follow advice from Dji Susan in post #4 and supply all data requested.
Good luck.
2022-9-4
JJB*
Hi,
Checked your flightlog, flying in RC Mode3.
Indeed after autotake off and after zero on the UP stick, craft did climb on its own!
(see the blue bar height line ; yellow = uncontrolled climb.
In the log no errors for hitting a wire or any other object in air.
In the log at 42.2secs  a weird value seen ; DroneOnGround !  just one entry, never seen this before in many many logs i have checked.
Checked the 2 batt cells, normal values up to the last record.
For sure someting wrong with your Mini3 Pro !   But what ?  i cannot give a good explantion, hope that DJI can.
But i do a guess ; as the log stops suddenly with all normal indications it looks like a power failure to me.
cheers
JJB
2022-9-4
Drohnenfieber
Flight distance : 310840 ft
Maybe upwind from the cliffs?
2022-9-4
