ejwjohn
Flight distance : 177408 ft
Apologies, if it sounds confusing... i am trying to plan ahead...
I am still relatively new to Drone flying and DJI, and over the months i keep reading the posts on this and other forums, and repeatedly the subject of uploading the log files to Phantom Log viewer keeps coming up, especially when pilots have experienced some unknown or unexplained event with their Drone.
So i wanted to make sure that in the event i had a similar experience i know how to get the relevant info out there for the experts on the forum to offer advice etc.
Simple i thought but then the issues started to appear, the log viewer will only accept.txt files and the DJI assistant 2 only exports the log files in .Dat format files.....
TO convert .Dat format to txt or CSV, you need a utility called DatCon, which i have, however that utility is not compatible with DJI Assistant 2 so you have to use another utility called ExtractDJI.jar, which i have and when I use it I cannot get any resulting exported files...... so i cannot use the log viewer as i do not have access to the compatible files needed.
And this is the issue right now.
JohnW |
