Bob Brown
Flight distance : 4209662 ft
reyd8 Posted at 9-19 11:06
I'm having the same issue. The Goggles even pinch my nose closed enough that I have to mouth breathe. My nose isnt that big. The only place the faceplate touches is right in the center of my forehead, and my nose. The bottom of the faceplate is a good half inch away from my face. I essentially have to skip the head strap and hold the goggles by hand. After 1 week, I have bruising on the bridge of my nose, so i'm pretty much not flying it now. Makes the Fly more kit that is arriving tomorrow seem like a waste of $$. I can barely make it through one battery before my nose has had enough. I have been using a Quest 2 VR headset for over a year, and the fit is fine. Heck the Quest 2 doesn't even touch my nose. I suspect that I will need to cut the entire nose bridge pad off of the face plate. if more than just the forehead of the faceplate would actually touch my face, this wouldn't be as big of an issue. For the price DJi demands for this headset, which only comes with 1 controller option that won't even allow you to use the Avata to it's fullest (flying in reverse and " strafing"), a little bit more R&D should have gone into the fitment of the Goggles 2. They are goggles, their #1 main function is to fit on your face. How they got that so wrong is beyond me. The Goggles 2 do not stand up the level of quality I have come to expect from DJI.
Yup I do a battery and then take a break while rubbing/messaging my nose. I am guessing that the folks that designed and tested this are Chinese. The facial profile is very flat and much different than anyone else in the world. I am hoping that soon there will be aftermarket options that replace the original. But for now the breaks between seem to help. (note: Fly more is a waste of money... until they fix this because you can charge a battery while you fly and take a break... 2nd battery will be all charged up in like 45 min using the correct charger.) |
