New DJI Terra Released (9/5/2022)
1484 4 2022-9-5
DJI Support
Flight distance : 2408 ft
South Africa
Overview:
Version: 3.5.5
Release Date: 2022- 09- 01
Update details
Optimization
  • Optimized the accuracy of aerotriangulation and GCP position prediction when vertical coordinate system of GCP is set to Yellow Sea 1985 height and Constrain with Image POS Data is enabled.
Fixes
  • Fixed issue where 3D reconstruction fails after customizing side length for block splitting in arbitrary coordinate system.
  • Fixed issue where map search function is unavailable when map source is set to Tianditu.
  • Fixed issue where importing KML to ROI fails when using KML files generated from LocaSpace Viewer.
  • Fixed issue where progress stays at 100% for a long time when using a great amount of data and selecting XML for aerotriangulation computation.
  • Fixed issue where start and end points of block display incorrectly after customizing side length for block splitting in arbitrary coordinate system.
Note
  • Reconstruction results generated using the Seven-Parameter Transformation function and coordinate systems of newly supported countries on v3.5.0 cannot be properly displayed and the Annotation and Measurement function is unavailable on v3.4.4 or earlier versions.
  • v3.5.0 and v3.4.0 involve the reconstruction algorithm upgrade, which requires upgrading the driver version of the NVIDIA graphics card of the computer device to v452.39 or above. Please upgrade in time to ensure the normal use of the reconstruction function. For details, please refer to NVIDIA Graphics Card Driver Upgrade Guide.
  • If corrupted file is prompted or no response when installing v3.5.0 software, right-click the downloaded installation package and select Properties. Under the General tab, you will see message " This file came from another computer and might be blocked to help protect this computer " at the bottom of the window. Select Unblock and then click Apply > OK.
  • Agras T10 or T30 users should use Agras drones with up-to-date firmware version to access Agricultural Applications.
  • Agras T16 or T20 users should use Agras drones with specified firmware version to access Agricultural Applications (Please contact DJI Support for the firmware).
Supported Aircrafts - Route Planning
  • Phantom 4
  • Phantom 4 Pro
  • Phantom 4 Pro V2.0
  • Phantom 4 Pro + V2.0
  • Phantom 4 Advanced
  • Phantom 4 RTK (MONITOR RC)
  • Phantom 4 RTK (NO-MONITOR RC) (Only supports importing Detailed Inspection planning route)
  • Matrice 300 RTK + H20 Series payloads (Only supports importing Detailed Inspection planning route)
  • Mavic 2 Enterprise Advanced (Only supports importing Detailed Inspection planning route)
2022-9-5
Montfrooij
Flight distance : 2408829 ft
Thanks for the info!
2022-9-5
Zaskar871
anyone advise me how to ecport a 3d model from terra to 3D CAD? [Please]
2022-9-7
Frontliner 2020
Philippines
Thanks for the update...
2022-9-7
rkmfl
Did you forget to mention support for the Matrice 200 series (eg - Marice 210 RTK v2)?
You mentioned only included the Matrice 300 RTK.  You would never force-extinct your enterprise $30,000+ drone packages, would you?
2022-10-24
