No motion data found in Avata video - Gyroflow
12Next >
15298 47 2022-9-5
Ken-W
Flight distance : 394626 ft
United Arab Emirates
I'm new to Gyroflow so please excuse the ignorance
I've transferred the video files from the internal memory of my Avata to my Win10 machine and loaded it into Gyroflow. Gyroflow can't find a lens profile and motion data for the video. What I am I missing here?
Thanks in advance!
2022-9-5
nosnoop
Flight distance : 237953 ft
Make sure electronic image stabilization (rocksteady) is turned OFF.
And field of view is set to "Wide" and NOT "ultra-wide".
Otherwise, you won't get the data recorded.
2022-9-5
Ken-W
Ah, got it! I'll dial those in now - thanks!
2022-9-5
DJI Paladin
Flight distance : 318 ft
Hi there, Ken. We're glad that you already mange to isolate your query with the help of our fellow DJI Pilot. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2022-9-5
fansb947a5ef
Israel
Having the same issue.file size is approx 2.6gb EIS is off and capture method set to wide. Other shorter videos I captured on the same day with the same settings work with no issue. Any ideas why gyroflow not recognizing lens settings?
2022-9-15
djiuser_i7lv8ZtBEVas
I don’t have gyro info either. Wide setting and EiS off
2022-9-15
fans622f4215
Flight distance : 7538878 ft
Dominican Republic
I don’t have gyro info either. Wide setting and EiS off. need help
2022-9-16
Sengtavanh
Flight distance : 11404 ft
fans622f4215 Posted at 9-16 16:52
have you found a fix ? I'm having the same issue,
4k 50
EIS Off
Wide
2022-9-16
K9DR
Flight distance : 628022 ft
Same problem.  I have EIS off, set to wide, but no gyro data showing
Edit - think I found the problem.  When I updated my goggles to allow me to fly the Avata, it didn't update the drone.  I am operating on 0.05.**  So need to update the Avata firmware and I suspect it will work fine.
2022-9-17
fansb947a5ef
Israel
My firmware is all up to date. Strange thing is that some footage contains gyro info but others don’t. Any ideas ?
2022-9-17
Airmaxx23
Flight distance : 436824 ft
I just downloaded GyroFlow, hopefully this gets figured out soon.
2022-9-18
Airmaxx23
It's working fine for me with EIS off and FOV set to wide.
2022-9-18
KlooGee
Flight distance : 16783757 ft
Three things are required:
- firmware v01.01.0000 or newer on the drone
- EIS: off
- FOV: wide
If you have all 3 of the above, you’ll get gyro data.
2022-9-18
fansb947a5ef
Israel
KlooGee Posted at 9-18 16:53
- EIS: off
Got all the settings you suggested and still having some videos showing no gyro info while others have
2022-9-19
KlooGee
These aren’t files you’ve merged are they?  The v1.2 release version of Gyroflow had some problems with merging files.  The latest dev version resolved that problem, but not sure if that’s what you are running into.
2022-9-19
fansb947a5ef
Israel
Unmerged files. Had a warning during the flight that the googles IMU needed calibration not sure if this might affect gyro info
2022-9-20
jentevc
Belgium
I had the same problem. try to re-input the file into Gyroflow, that worked for me.
2022-9-21
HarryCallihan
Doesn't work for me, either. Everything updated.
Update: Never mind. Works great.
2022-9-25
fans99f9ca89
HarryCallihan Posted at 9-25 10:28
What was the problem? I'm stuck with this
2022-9-25
kneeboardking
Flight distance : 3436263 ft
- EIS: off
I had the same issue (no gyro data in avata video files) had already updated that afternoon and checked firmware again as was not unto version v01.01.0000 doing that fixed it for me.
2022-9-28
fansb947a5ef
Israel
Would gyro info depend on flying in normal or manual mode ?
2022-9-28
fansdba05b67
Flight distance : 881237 ft
I have rocksteady off and FOV set to Wide  and when I drop my file into Gryroflow it tells me that no gyro data is available for the video.    I am updated on the goggles and drone both to the most recent DJI firmware.
I also just re-updated the drone and goggles both to the newest firmware and still no gyro data?
this is frustrating because I have some cool clips, I want to stabilize!   hate to keep flying them and flying them and it's not working!!
2022-10-8
djiuser_H0OTRZv0bTGg
Flight distance : 242625 ft
I updated firewire and everything. I haven't gotten any Gyrodata. EIB off, WIde On. No idea what to do
2022-10-10
fansdba05b67
Figured it out...  all in one pack
1. Took off in EIS off - Wide , Landed
2. Took off in Rocksteady - Wide , Landed
3. Took off in Horizon Stabilization - wide , Landed
4. Took off in EIS off - Wide , landed
and ever since it's recorded Gyro Data
2022-10-12
fansdba05b67
djiuser_H0OTRZv0bTGg Posted at 10-10 16:21
2022-10-12
migostudios
Flight distance : 3013307 ft
Portugal
Same issue here... cant seem to figure out how to make it work...
This is my second avata, first worked fine, this one doesn't seem to record gyro data...
2022-10-15
teddynosoucy
Israel
same issue...any bug fixes ?
2022-10-20
djiuser_TKPab9ZztVFT
Bangladesh
I found a solution: make sure your sd card is within the drone itself, not in the googles. Previously when my card was in the googles it did not record any gyrodata.
2022-11-3
aRandomPers0n
[Post was removed due to wrong information]
2022-11-8
alex5
Having the same issue. Tried the taking off and landing with all modes in the same pack but issue persists. Any fixes yet?
2022-11-8
bplatel
I also can't get it to work.
I am certain that I have all these:
- EIS: off
- FOV: wide
But still, I get the message: "File format was detected, but no motion data was found. The camera probably doesn't record motion data in this particular shooting mode." in Gyroflow when I try to import the mp4 files.
Any ideas?
2022-11-11
Kalmuraee
Saudi Arabia
Same issue here
2022-11-25
FPVTrendz
Flight distance : 1241020 ft
I don't know if this is the issue, and I'm not suggesting that anyone is doing this, but be sure the footage is from the Avata and NOT the goggles. All goggles footage is raw, only the Avata footage is going to have the gyro data in it. Hope this helps someone
2022-11-25
Kalmuraee
Saudi Arabia
EIS is off,
FOV: Wide
Recording on the avata,
Firmware is updated to the latest
And Still I'm unable to have gyro data with the recording ... anything else I should try ?
2022-11-25
Kalmuraee
Saudi Arabia
It's working, it turned out I had to update the drone's Firmware V01.01.0200
2022-11-25
djiuser_wOuESA1ulLxX
fansdba05b67 Posted at 2022-10-12 16:07
I was having the same problem and this fixed it for me. Thank you!
2023-1-15
ro_walker
Brazil
2023-1-15
DavidKuma
Flight distance : 1475984 ft
Originally the gyro data was saved as a separate file.
With the updates the gyro data is now INSIDE the .mp4 file.
GoPro files work like this.
Try dragging and dropping (or importing) only your .mp4 files into Gyroflow.
I hope this helps.
2023-3-5
ro_walker
Brazil
Ken-W Posted at 2022-9-5 22:07
2023-3-13
Pluszak04
Flight distance : 240817 ft
Norway
Where is dji support? Why they don’t answer
2023-3-27
12Next >
