sd cards in drone and goggles
2871 13 2022-9-5
stevejusto
Flight distance : 2661624 ft
whats the benefit of installing a sd card in the goggles when i have one in the drone ? and when record is pressed do the goggles  and drone record the same footage at the same quality.
2022-9-5
StuntJumper Ste
Flight distance : 56949 ft
Putting an SD card in your goggles records basically what you see through the goggles with the Hud ie, height, speed etc. And is at a reduced resolution of 1080p.
I personally use it as a safety thing, as in if I ever lose connection( which is likely in CE regions) I can play it back and have an idea where it might be if it crashes or doesn't rth.
2022-9-5
animale
Flight distance : 1720039 ft
Greece
StuntJumper Ste Posted at 9-5 23:57
If I'm not wrong, you can see the last thing the goggles received before disconnection, even without an SD card. Go under Settings > Safety > Camera View Before Loss
2022-9-6
stevejusto
thanks for you answer, this is a good idea.
think i will do the same and format the card in the goggles  before each flight.
2022-9-6
fans07bc0ba6
Flight distance : 1393255 ft
animale Posted at 9-6 00:29
Do you know how to export this file from the cached storage. I didn't have a SD card in the goggles, but the crash footage is there... and it cuts out well before on the drone SD card. which leads me to believe it is a faulty drone.
2022-9-7
Lucas626
Flight distance : 50642090 ft
I was just going to ask this question.  Thanks all.
2022-9-7
Chaosrider
Flight distance : 1226762 ft
This caused me to look at the whole CE thing from a different perspective.
So, one might argue that the CE restrictions on transmission power and range actually increases the danger of a crash, and hence, increases the risk of injury to persons or property on the ground, compared to the much more reasonable FAA standards.
Just another hazard of living in an overly restrictive country, I guess...
TCS
2022-9-9
zvandorn13
Flight distance : 166991 ft
fans07bc0ba6 Posted at 9-7 15:44
Did you every figure out how to get the footage from the cache on the goggles?
2022-10-7
CutAussie
Flight distance : 336657 ft
zvandorn13 Posted at 10-7 16:54
I just take card out of goggles and put it into my computer or iPad etc
2022-10-7
fansf8cb6503
Flight distance : 1303533 ft
Same problem here, no SD card, tried different types, fully formatted, still no success. Reading up it's a common glitch, that can't be rectified without DJI offering a free product recall.
2023-1-12
The Saint
Flight distance : 5902228 ft
fansf8cb6503 Posted at 1-12 08:30
there's no reason to issue a recall as long as there is no safety issue.
2023-1-12
Ryan70
Flight distance : 6556680 ft
stevejusto Posted at 2022-9-6 00:29
Just curious why would you reformat the sd card before each flight?  You ccan save a crap load of data on a small 128 GB sd card in the Goggles.
4-12 16:03
Mr. Mucus
An SD in the goggles will record your flight with telemetry data.  You may not "need" it but it is nice to have, especially if you crash or lose the drone.
4-12 18:42
DJI Paladin
Flight distance : 318 ft
Ryan70 Posted at 4-12 16:03
Hello, Ryan. Thank you for reaching out. It is unnecessary to reformat your SD card each time before a flight, we suggest doing reformatting after you back up the files inside the card and if you need fresh storage before filming. Should you have other inquiries or concerns, feel free to contact us. Thank you for your valued support.
4-12 22:17
