Clementinho
Singapore
KillerKingSSS Posted at 9-9 19:53
Yes they match as with any other camera... You only have to match the Alexa Mini or Sony Venice footage to the Ronin 4D, thats the trick.Since the other two cameras can shoot on RAW, you have more headroom to recover highlights and shadow detail, right now, you're a little more limited on the 4D so be precise on the exposure, stablish the look of the scene on the camera with less headroom and then match the others. Another trick is using a chart for every light setup and then balance all the shots to that.
Theres no problem. Thanks for the reply. I think I need to clarify that I am asking if the Ronin 4D Rec 709 LUT matches with the Arri Rec 709 image ON SET. The reason is because when shooting I need to monitor and match the cameras in terms of lighting, exposure and white balance. I’m pretty confident of matching them in post but the issue is with working with the two cameras simultaneously on set. |
