ISO long USBC AirS2 Cable
513 3 2022-9-9
PCDC IT
Good Evening,
I am in need of a longer USB-C to USB-C cable that is compatible with the AirS2, the stock cable is not long enghouh to reach around an ipad and I cannot find a long enought cable that is compatible. Reached out to DJI for them to say they dont make a longer on but they still recommend to use a DJI cable as most other will not work. Does anyone know of a USB-S cable that is compatible.
Thank you in advance.
2022-9-9
DJI Stephen
Hello there PCDC IT. Good day and thank you for reaching out. You may try check our DJI Where To Buy platform on this link ( https://www.dji.com/where-to-buy ) to see if those cables that you need is available. In addition I hope that you can get some recommendations from our DJI Co pilots with regards to this inquiry. Thank you and please be safe always.
2022-9-9
FabioV
Flight distance : 2185043 ft
For downloading the videos I’m using the USB-C to USB-C cable provided with the MacBook Air battery charger and it works perfectly.
2022-9-10
chillibadger
Flight distance : 233064 ft
If you can get spare parts would the cable they supply for charging the mini 3 be long enough?
2022-9-10
