Joysn
![](https://forum44.djicdn.com/data/attachment/common/d3/common_10_usergroup_icon.png) lvl.1
Austria
Hello,
how can I extract valid temperature values from the RJPEG files for post processing? Tried with DJI thermal SDK, does not work reliably. Get temperatures from range -40 to +120° Celsius. On a day which had around 20°C. Even all DJI Termal Analyzer tools (version 1 to 3) show wrong temperature values.
When I read exif image meta data, I find K1, K2, K3, K4, KF, B1, B2, D1, D2, KJ, DB, KK. What do these values mean? Not sure how DJI calls this meta data, but "exiftool" calls it like this. Seems that somebody did reverse engineering due to poor documentation from DJI.
Even when I extract the raw data values, they seem to be wrong as well. At least when I create a histogram for temperature and raw values, they seem to have the same issues, but as I dont know how to process the sensor raw values, I cannot tell if the sensors raw values already have issues.
I can play with the parameters humidity, emissivity, distance and reflected temp., but I do not get feasable temperatures.
Furthermore, minimum temperature can jump from -2°C (which is already not feasable on a day with min. ~10°C) to around -20°C on two consecutive photos within 3 seconds.
Might there be a sensor issue?
Or am I doing the measurements completely wrong?
