DJI Tony
Adrian Borza Posted at 7-18 03:14
I suffered the same as MBo. On the last flight, the drone (DJI Mini 3 Pro with smart remote control) worked properly. After a break of a few weeks when I wanted to film a fishing competition I had the unpleasant surprise that the drone did not send any image to the remote control and the error message Gimbal IMU data error (code 40021) appeared. When I got home, I redid the firmware update on the drone and the remote control from the PC, with the latest version, but the problem was not fixed. I noticed that the SN of the camera is no longer displayed for me either, as if it does not physically exist in the drone. I note that the drone was not hit, it did not fall. Everything works (it flies, the gimbal moves as it should, I did the calibrations successfully) but I have no image from the camera anymore. I suspect that the problem appeared after the last update. I am very dissapointed.
Hello there. I'm sorry for the experience. Was this already resolved? If not yet, please try the steps below:
1. Please make sure you're using the DJI Fly app.
2. Make sure the connection between the mobile phone device and the remote controller and the connection between the drone and the remote controller has been successfully connected, and relink the aircraft to the remote controller.
3. If there's a microSD card mounted, we recommend removing the microSD card, rebooting the device, and trying again.
4. Please make sure the version of the drone, remote controller, and the app is the latest. When the microSD card is not mounted, refresh the aircraft or the remote controller firmware.
5. Please reset the camera settings. After resetting the camera settings, please check if the photo and video can be shot normally. If not, the photo or video also shows black, you might need to send the drone for testing.
6. Please replace the mobile device to have a try if possible.
I hope this helps. Have a great day ahead. |
