Apple screens dimming and workaround
4338 16 2022-9-12
Bashy
Flight distance : 2354357 ft
Hi folks, been reading lately that if you put the device into low power mode and possibly DND, it will not dim.
Another is,
You can switch zoom text (all interface) in settings to max and then back.
After this dimming protection will stop
See how it goes and report back, please? interested to know is all, i don't have any apple stuff myself lol
2022-9-12
Montfrooij
Flight distance : 2845026 ft
Interesting.
I will test when I fly again.
2022-9-12
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Hope that you could get the best suggestion from our fellow DJI Pilots here that currently using Apple devicess. Should you have other inquiries, please don't hesitate to reach us. Have a nice day ahead!
2022-9-12
FabioV
Flight distance : 2111709 ft
The low power mode reduces the brightness of the screen, then I'm not sure it's the right setting to play with. For sure, the auto brightness can be disabled going to Accessibility -> Display & Text Size. This should prevent any modification of the manual brightness, assuming that also 'Reduce White Point', Nigh Shift and 'True Tone' are disabled too.
2022-9-12
Bashy
FabioV Posted at 9-12 23:56
Just try it and report back, i don't use them but thought i would share because if it is true then its a game changer for apple lovers
2022-9-13
TomKatt
Flight distance : 115184 ft
I use an iPad Mini 5 and never had any issues with the screen dimming (unless the battery gets critically low)...  I'm wondering if the Auto-Brightness feature is enabled on your device as FabioV suggested?  I always disable that feature straight away because I find it distracting, and it could be the source of your concern.
2022-9-13
TonyPHX
Flight distance : 12142077 ft
TomKatt Posted at 9-13 08:38
The IOS dimming issue is independent of the auto-brightness issue.  This primarily affects drone pilots flying in warmer climates or when your device is catching direct sunlight.  IOS progressively dims the display and it can be quite disconcerting when you realize you can no longer read the dispaly.
It does this to protect the phone and battery and cannot be turned off.
2022-9-13
TomKatt
TonyPHX Posted at 9-13 08:52
It sounds like we are talking about an overheating issue rather than auto-brightness.  I've left my iPad in the direct sun and I've occasionally observed warnings about overheating - I think the display did dim in that instance as a protective measure.  But this has never occurred during normal use - only when I've left the device on a table for example.
Perhaps I'm just lucky that I live in the temperate Northeast...  Until we need to get the snow shovels out lol.
2022-9-13
DowntownRDB
Flight distance : ****
TomKatt Posted at 9-13 08:57
I left my snow shovel in in the Northeast when I retired to Florida.
2022-9-13
TonyPHX
DowntownRDB Posted at 9-13 10:54
Location is everything!  : )
2022-9-13
gulfpre
Flight distance : 2885656 ft
Where about? RSW here.
2022-9-13
gulfpre
For sure. South Florida here… heat soak, sun soak, cpu running… it’s all bad. Also making sure controller to phone charging is disabled helps a little… but in the end the phone always wins.
2022-9-13
TonyPHX
gulfpre Posted at 9-13 18:02
Agreed.  That's why I tell anyone that will listen, don't fight against IOS devices for drone flying.  Just when you think it won't happen to you.... it does.  I burned too many hours with various IOS devices, cases, even cooling solutions, and well, if you live in the wrong climate, it is a recipe for a migraine.  These threads still pop up though.... but each new IOS version gets better and better about protecting against overheats.  And of course protection is great, but not if you are wanting to see your display.
2022-9-13
DowntownRDB
TonyPHX Posted at 9-13 15:24
Indeed it is Tony.
Hope you are having a great day.
2022-9-14
DowntownRDB
gulfpre Posted at 9-13 18:00
Northeast Florida.
2022-9-14
TomKatt
Deep in the sticks of VT.   Foliage season is just beginning - makes for some great photos ;-)
2022-9-14
fans78766c93
Flight distance : 24576168 ft
Philippines
Same thing happens with my Huawei phone. It's ok at first, and in less than a minute the screen is so dark I can hardly see it. I'm in the Philippines, temperature 90F + and direct sun on the screen. I have no control over these conditions.
2024-4-25
