Mini 2 swimming with the fishes
12Next >
1063 40 2022-9-14
DronesJones
Flight distance : 4861152 ft
Hi Guys,
I had a little incident where the mini 2 decided somehow it was too high and took a dip into the drink.
I was watching it while it happened, taking a shot flying backwards away from us and the drone started from what looked to be about 9-10 feet altitude above the water.
My intent was to get a shot of us on the water with the drone accelerating away from us backwards, I understand that its not recommended to fly right above the water but this seemed  like it had plenty of buffer to me to stay in the air.
Here is the log
https://www.phantomhelp.com/logviewer/9WRXVW39UEODULN0FBCS/
What would have caused it to decent into the water on its own like that? I have never seen it drop more than a foot or two even on windy days on its own before
Thanks
2022-9-14
Johnny_J
Sweden
Maybe it was hungry and saw some fish?
It's 'fish', plural btw, not 'fishes' ...
2022-9-14
DronesJones
Johnny_J Posted at 9-14 07:46
Thanks for the grammar check but I'm pretty sure it's correct as used.
https://idioms.thefreedictionary.com/swimming+with+the+fishes
2022-9-14
Mobilehomer
Flight distance : 18150351 ft
DronesJones Posted at 9-14 08:47
Fish generally refers to multiple fish of the same species. Fishes refers to multiple species. Both are correct.
2022-9-14
DronesJones
Mobilehomer Posted at 9-14 08:52
That's right, but it would be "swimming with the fishes" or "sleeping with the fishes" in TV and Movie land.
2022-9-14
SpectreOne
Flight distance : 79659 ft
I love when a good thread heads down a rabbit hole! Or is it rabbits hole? LOL
2022-9-14
chillibadger
Flight distance : 233064 ft
I know that flying over grass on a hot day causes lift and wet grass causes descent.
2022-9-14
DronesJones
chillibadger Posted at 9-14 10:23
I have never really noticed that before, but we are talking about 9-10 feet of un-commanded descent here, not a little bit of deviation.
I realize that at some point the IMU altitude started to read a little lower than it actually was, but I would think this would have the opposite effect and make the drone want to climb... I am a bit puzzled as to why this happened the way it did.
2022-9-14
blue_canyon21
Flight distance : 23418189 ft
It's extremely well documented and tested that unstable ground and water will mess with the VPS.
Flying low over water is just generally a bad idea.
2022-9-14
DronesJones
blue_canyon21 Posted at 9-14 11:08
Understood, however I don’t believe that 10 feet is low enough, or even that the VPS sensor is at fault here, the vps reading seems more accurate than the IMU altitude at some parts of the log.
2022-9-14
JJB*
Flight distance : 12445630 ft
DronesJones Posted at 9-14 10:54
Hi,
Last part flying really fast backwards in Sport mode, high drone pitch up value : VPS height lost its height.....wich is not a surprise with nearly 40 degree Up pitch.
Flying VPS height at 2.5 meters above water, lost height track..
In sport mode with high drone attitude values (especially backwards) ; Mini2 has difficulty to keep height steady....
Would happen also when flying low fast backwards over land....
See my charts of your data. (see the blue and green VPS line)
cheers
JJB
2022-9-14
DronesJones
JJB* Posted at 9-14 11:17
Hi,
Thanks for the analysis that looks a little better than the phantom help viewer.
What I don't understand though, is I launched the drone from my hand about 4 feet off the water, why is the IMU altitude showing 4.9 feet when it hits the water at 3m 9.2s ?
According to my logic, 0 feet IMU altitude should still be 4 feet off the water shouldn't it?
2022-9-14
JJB*
DronesJones Posted at 9-14 11:24
Hi,
changed my view to feet...
at 3m9.2s : baro height = 5.2 feet, bottom sensor height = 2.3.
But as you see not a steady value, due to high pitch up drone angle.
Drone hits water at 3m9.1s, height 1.3 feet. (see the drone pitch/roll angels at impact)
Baro height is set to zero at takeoff, so if you let the drone steady touch the water than the baro height reads minus 4 feet, bottom sensor reads 0.0.
PS about keepin height, if i fly at 300 feet full speed forward in sport mode, sometimes i loose some height (but will be corrected in time) but as you cannot see that from large distance no one knows or mind....
Only analyzing logs will show height variations....
cheers
JJB
2022-9-14
DronesJones
JJB* Posted at 9-14 11:34
Hi,
Funny thing is I have done that shot a bunch of times, some even significantly closer to the water and never had a problem with the drone dropping altitude... At least not more than a foot or two anyways... Kinda strange that the IMU is reading positive values at the end, it should have been at 0 feet by the time it got level with our heads.
I wonder if it's worth diving for
2022-9-14
Labroides
Flight distance : 9991457 ft
DronesJones Posted at 9-14 12:27
It's not strange at all.
Because the height you see on screen comes from measurements of changing air pressure, it's common and normal for differences of 10 feet or so over the duration of a flight.
You were flying closer to the water than you realised and couldn't see how close because you flew backwards.
Flying close to an obstacle (like the lake surface), at full speed in Sport Mode is always going to be risky.
2022-9-14
DronesJones
What is considered a safe altitude then to fly over a lake? I was told 10 feet by several people so that’s obviously not quite enough then if you can’t trust the vps over water and the imu altitude is inaccurate
2022-9-14
Labroides
DronesJones Posted at 9-14 15:31
You can trust VPS over water, but VPS can't work properly at the tilt angle you get with full speed in Sport Mode.
There's no magic distance from water (or any obstacle) that is safe/not safe.
But if you can't see the gap between the drone and the water, and you want to backwards fly in sport mode, do it where you can clearly see the gap with your own eyes and respond accordingly.
2022-9-14
TonyPHX
Flight distance : 11229610 ft
Here is my analysis after some careful review.  You crashed your drone.  Now you just need some a bag of rices.
2022-9-14
DronesJones
TonyPHX Posted at 9-14 16:45
Haha and a scuba diver
2022-9-14
TonyPHX
DronesJones Posted at 9-14 16:47
Long stick!!  Maybe we need a drone retrieving submarine from DJI??  : )
2022-9-14
Mobilehomer
TonyPHX Posted at 9-14 16:54
2022-9-14
fanse0f68750
Flight distance : 239672 ft
I have flown low over water many times with a mini 2. I always lower it to 5ft above water and them give it full stick forward, backward, or sideways and have been lucky I guess.
2022-9-14
DJI Stephen
Hello there DronesJones. I am sorry for the trouble this has caused and thank you for reaching out. Since this unfortunate event happened to your DJI Mini 2, I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do there best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2022-9-14
TonyPHX
Mobilehomer Posted at 9-14 17:36
https://youtu.be/-BX1b6YBVP4
I think I want one of thes!
2022-9-14
Blériot53
Flight distance : 6188465 ft
Dirty Bird Posted at 9-14 13:04
You never watched "The Godfather", where Luca Brasi was described as "sleeping with the fishes"?
Or read the bible parable :  Loaves and Fishes
2022-9-14
Montfrooij
Flight distance : 2560453 ft
I have flown over water (quite low) with the Mini 2, but never in sports mode.
Not sure if that will increase the risk of drone dipping, but thanks for the (expensive) lesson you gave me!
2022-9-15
DronesJones
Montfrooij Posted at 9-15 00:29
Apparently it does, I am thinking that the wind created by the speed affected the barometer, I have video of it... It suddenly just descends into the water about 8-10 feet a bit after changing to sports mode. I wish I was watching the screen and not the drone because on the video its super obvious that it started dropping, watching the drone from the boat it was not obvious at all until there was a splash.
2022-9-15
DronesJones
fanse0f68750 Posted at 9-14 18:40
Me too thats why I am a little shocked this happened, I crashed my first mini due to not knowing all the flight modes properly, not understanding to wait for GPS or what ATTI mode was.. But I like to think I have been pretty careful to follow the recommendations since then and I thought the drone was sufficiently high that it wouldn't just dip into the water like that.
2022-9-15
chillibadger
That is so awesome
2022-9-15
Mobilehomer
TonyPHX Posted at 9-14 21:18
Here is Captain Drone's review -
2022-9-15
DronesJones
Yeah, I wish I had one for a search and rescue mission
2022-9-15
Chaosrider
Flight distance : 1226762 ft
Not if you're Luca Brasi.
He definitely swam with the fishes...
TCS
2022-9-15
Montfrooij
DronesJones Posted at 9-15 07:02
Yeah, hindsight is always more clear.
It's a hard lesson man. And I wish we could do anything about it.
TBH, I always fly very low over water and so far that went perfect.
I do stay in normal mode and watch the screen mainly (because I usually can't see the drone).
And I know it's a risk.
But I figured I'd rather take a (calculated) risk and get some very nice footage than only fly the safest route and get the same (boring) shots as usual.
2022-9-15
Labroides
DronesJones Posted at 9-15 07:12
You thought that, but ......
The drone was too far away for you to see how close it was to the water.
If you had forward vision, the wideangle lens makes things appear further away than they really are.
You were flying it backwards  so you had no forward vision.
You flew at full speed in Sport Mode, very close to a big obstacle.
If you want to engage in risky flying, do it where you can see what's happening.
2022-9-15
Bashy
Flight distance : 2354357 ft
Yep, sports mode will make the drone lose altitude and its especially noticeable when low to the ground, what's worse is, that you were going backwards, therefore it was nose up so you couldn't see on the live view what was actually happening, I am surprised it didn't say Landing but that must be the downward sensor and water issue, i.e. it couldn't see solid ground. A shame, you need to find a local diver or club, good luck.
2022-9-16
DronesJones
Bashy Posted at 9-16 04:31
Hi Bashy,
On the video it’s super obvious that it was dropping however I was watching the drone directly and not the screen, it was not nearly as obvious watching the drone as it didn’t start to drop at first until it was far enough that it looked like it was just moving backwards still.
2022-9-16
hunterws
Flight distance : 382536 ft
Why not just use the dronie shots?  (canned program)
2022-9-16
DronesJones
hunterws Posted at 9-16 11:02
Not really the effect I was going for, I have done this shot before and it usually goes fine and looks great, focused on a subject accelerating rearwards away from it at a constant altitude
2022-9-16
MBSL500
Because he did not actually use the word *fish*, you should have used asterisks rather than apostrophes.
You should have also used quotation marks rather than apostrophes (“fishes”).
A period at the end rather than "..." what have also been correct.
Class dismissed.
2022-9-17
DronesJones
MBSL500 Posted at 9-17 07:43
lol ok bud, you clearly missed the point on this one...
2022-9-19
12Next >
