KleytonKivel
Flight distance : 61995 ft
Brazil
After carefully read the user manual (I should have done that from the start ).
I notice that the Downward Vision System consists of two cameras. The Infrared Sensing System consists of two 3D infraredmodules. The Downward Vision System and Infrared Sensing System help the aircraft maintain its current position, and the Downward Vision System works best when the aircraft is at an altitude of 0.5 to 10 m and its operating range is 0.5 to 20 m. The FOV to the front and rear is 106° and 90° to the right and left.
So if I manage to take of over a blanket and keep the altitude higher that 0.5 meters, I can flight normally inside my apartment. Even with the floor pretty regular.
Notice this warning in the manual:
The vision system cannot work properly over surfaces without clear pattern variations or where the
light is too weak or too strong. The vision system cannot work properly in the following situations:
a) Flying over monochrome surfaces (e.g., pure black, white, red, or green).
b) Flying over highly reflective surfaces.
c) Flying over water or transparent surfaces.
d) Flying over moving surfaces or objects.
e) Flying in an area with frequent and drastic lighting changes.
f) Flying over extremely dark (< 10 lux) or bright (> 40,000 lux) surfaces.
g) Flying over surfaces that strongly reflect or absorb infrared waves (e.g., mirrors).
h) Flying over surfaces without clear patterns or texture (e.g., power poles).
i) Flying over surfaces with repeating identical patterns or texture (e.g., tiles with the same design).
j) Flying over obstacles with small surface areas (e.g., tree branches).
