Futaba T8J for camera control problems
864 1 2015-8-8
Ozren
Croatia
Hi all,
I have a Futaba 14SG as main controller, when i plug in trainer cable, Futaba 14SG automaticly turns on, i press NO, and it doesent transmit RF, thats it. On Futaba T8J, when i plug the trainer port, nothing happens.
Why?
Thanks alot !
2015-8-8
richardhuison
Flight distance : 54455 ft
Before you plug in the cable you need to run off the internal 2.4 control. On the Futabe hold down the middle menu button and turn on the transmitter. You will get the option to turn off the 2.4. Once done you can then p,up in the Trainer Cable
2015-8-8
