self-centering throttle
1980 5 2022-9-17
barakgoren
Israel
hi, i just get the dji fpv and until now i trained with a PS4 controller on the simulator, and after the first flight with the fpv i found out I more comfortable flying fpv when the throttle is self-centering, is there any way I can set the drone that the center of the throttle stick is not 50% power?
2022-9-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for bringing this query to us. The DJI FPV throttle stick cannot be customized or changed. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2022-9-18
DronesJones
Flight distance : 4861152 ft
Hi, I think I felt like that initially too but I can assure you if you are using manual mode it is much better to have the throttle stay where you put it, the drone will always have a tendency to take off into the sky with it self centering.
2022-9-19
Chaosrider
Flight distance : 1226762 ft
DronesJones Posted at 9-19 05:41
That hasn't been my experience. I've flown my FPV with no friction of the left stick at all. Right after I go into Manual mode, the drone has a tendency to drift up. I'm happy to have that be the "default action" for the throttle.
Recently, I've been practicing maintaining altitude within +/- 50 ft, over a course that's about a mile out and a mile back. I leave the throttle set, and see what angle produces level flight with that power. It turns out to be 50 - 55 mph speed, when I get the angle set right for that power setting to produce level flight.
At this point I like the "no friction" setting better. To be fair, I don't do any acro, and I can see why the throttle friction thing might be helpful for that.
I still land my FPV in Normal mode, and doing that with the throttle friction applied was a bit annoying.
YMMV
TCS
2022-9-19
DronesJones
Chaosrider Posted at 9-19 08:04
I think that makes a big difference, if you are hitting gaps and doing freestyle, the tendency to always ascend will cause a crash.. For purely cinematic flying with nothing ever above the drone, it could be just as safe with the drone wanting to ascend.
2022-9-19
Chaosrider
That's most of my flying, although "sightseeing" is probably a better term than "cinematic"! I'm just not that good with planned photography.
Good point about the flying under things though, I hadn't considered that specific use case.
Thx!
TCS
2022-9-23
