What could be causing this?
1053 7 2015-8-8
hungrydude5
http://youtu.be/wBqxpYJjCm8
I'm a train enthusiast, so I take photos and videos of well.....trains.  Take a close look, seems like the gimbal and the gopro shake slightly but very quickly.  Any ideas?
Hero4 silver
H3-3D (with interference board and white rubber dampers)
Phantom 2
All firmware up to date.
Ben
2015-8-8
christyindublin
i was just reading about this, the chap said he switched to the grey buffers and the shaking went away, ?
2015-8-12
hungrydude5
I did in fact switch to the gray/black absorbers and it seemed to do the trick.  Also, a very important note.  With the phantom 2 version 1, the horizontal motor touches the frame and it binds up a little bit.  So that's probably why I was getting the shaky video in the first place.  I just bought a phantom 2 version 2, and it has a cutout for that horizontal motor so it is completely isolated.
Ben
2015-8-13
nico_mav
Flight distance : 1858852 ft
Greece
Is there any scratches on the propellers ?
If your propellers are not in a good condition they produced vibrations.
2015-8-13
Cessna172
It's fun to watch trains.   Thanks for the video.   Glad you found and fixed the issue.
2015-8-13
roy
Nice idea even with a little shake .
2015-8-16
rixlumb1
nico_mav@hotmai Posted at 2015-8-14 03:24
If your propellers are not in a good condition they produ ...
This is true, even stock props on the P2 are not properly balanced. Carbon Fibre are even more out of balance.
I bought a simple aluminium polished balancing rod, opposite threads each end for about £5UKP, balance on a tin of peas or such (making sure the surface is level across the tin... smartphone app.)
I had to add a varying small amount of tape to the lighter side (rather than sand heavier side) to ALL 8 DJI  9450 props.It stopped all the shake and undulating jello effect plus your motor bearing will be happier and last longer!
2015-8-16
DJI-Dave
The gray buffers do seem to work better.
2015-8-16
