Quick Transfer does not work
24250 35 2022-9-18
fans4e8f2c69
Flight distance : 887461 ft
Belarus
Hello,
I did not use this feature too often and last time I used it it works perfect with old Huawei P Smart. However today I wanted to use it again (with Huawei Mate 20 Lite) and it does not work. The drone was detected by BLE (and allows to connect to its GATT service) but no Wi-Fi network created. I checked in both ranges: 2.4 and 5 - no network found. I thought that the issue with my phone and tried with Huawei P20 Pro - same result. But it still works with P Smart.
I tried to find a way to switch it to 2.4G only as it shown in connection dialog by Fly App but I was not able to find this settings in the app as well as on the phone.
So the question: how can I get it working?
2022-9-18
DJI-Osmo-User-1
I take it you have tried with all the arms unfolded?
2022-9-18
fans4e8f2c69
Belarus
DJI-Osmo-User-1 Posted at 9-18 09:33
How can it affect this? Any way, ether way it does not work.
2022-9-18
DJI-Osmo-User-1
You don’t get full speed, without unfolding you get the high interference msg, I didn’t think it would matter but it makes a huge difference
2022-9-18
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused. Can you please try to initiate the troubleshooting steps below to see if this rectifies the issue?
1. Ensure that the Wi-Fi, Bluetooth, and Positioning function are turned on in the mobile phone settings.
Note: In some Android mobile devices, the app Wi-Fi permission can be set separately. Check the Wi-Fi permission setting for the DJI Fly app and ensure that the Wi-Fi permission is allowed.
2. Try to use the Fixed 2.4 GHz function in the QuickTransfer Band. Go to the DJI Fly homepage - Settings - QuickTransfer Band - Fixed 2.4 GHz.
Note: If the connection failure can be resolved by using this method, it can be determined that the mobile phone’s 5G band does not cover 5.8 GHz.
3. Restart the mobile phone and aircraft.
4. Try to rename the aircraft and restart it.
In addition, if another mobile phone was connected to the aircraft using the QuickTransfer function, and the mobile phone is nearby, a possible reason for this message is that the aircraft’s Wi-Fi is occupied by the previously connected mobile phone. We recommend turning off the Wi-Fi on the previously connected mobile phone or deleting/ignoring the aircraft’s Wi-Fi. If the mobile phone cannot be found, please change the aircraft name in DJI Fly and reconnect to it.
Please keep us posted so we can help you further. Thank you for your valued support.
2022-9-18
fans4e8f2c69
Belarus
DJI-Osmo-User-1 Posted at 9-18 12:58
I can't get any speed because it doe snot work at all.
2022-9-18
fans4e8f2c69
Belarus
DJI Paladin Posted at 9-18 21:07
I tried everything. Also there is no such settings (I wrote that in my post). I have no Quick Transfer Band settings in DJI Fly app.
Drone does not turn WiFi network. I checked  it from all devices I have near me: router, PC, laptop, ESP32, Raspberry Pi: no one can see Mini 2 WiFi network. So I guess that the drone does not receive command over Bluetooth to turn WiFi network On.
2022-9-18
DJI Paladin
fans4e8f2c69 Posted at 9-18 22:39
Thank you for your response. Can you please try to uninstall and reinstall the application on the mobile device that experienced the issue? Please keep us posted. Thank you.
2022-9-19
fans4e8f2c69
Belarus
DJI Paladin Posted at 9-19 01:17
Already did few times. As well as had fresh first time install on P20 Pro (the app had never been installed on that device).
2022-9-19
btframework
Belarus
By the way, why the forum always resets the user name and I have to change it back once per few days?
2022-9-19
btframework
Belarus
Ok, I did more research with BLE Sniffer. So
The app sees the Mini 2 and able to connect to it
I used other tool (GattClient from Bluetooth Framework) to make sure the MAC used for connect (0x34D262892FBC) is Mini 2 MAC
So next DJI Fly able to read all the attributes (will not post all the images here but it does) and next it writes Client Configuration Descriptor for the Indicatable/Notifiable characteristic
After that it writes other characteristics and even receives notification
Next some other communication goes on and the last notifications received
After that the DJI Fly waits for Mini 2 Wi-Fi network but the network does not appear.
2022-9-19
btframework
Belarus
If you need I can collect Bluetooth HCI log from my phone.
2022-9-19
btframework
Belarus
I did more tests and found that sometimes communication stops right after writing to the Client Configuration Descriptor. After that nothing except keep-alive packets goes to/from Mini 2.
2022-9-19
DJI Paladin
btframework Posted at 9-19 03:00
Thank you for keeping us posted. Since you already maximize all the possible troubleshooting to possibly rectify the issue, but still the issue still persists, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your kind and understanding.
2022-9-20
btframework
Belarus
DJI Paladin Posted at 9-20 03:41
It seems very unreliable idea becasue, as I wrote and I hope you read what I wrote and don;t simple post answers from your script as robot, it works with other device. So the problem is not in Mini 2 but is in DJI Fly. All you need to do is simple forward all the information I provided to your developers so they can simple fix the bugs in your application.
Of course, if you agree to pay for just short Mini 2 cruise around the world, why not - I am ready to provide my bank details.
2022-9-20
TomKatt
Flight distance : 115184 ft
I haven't observed any "improvement" worth upgrading from my trusty v1.5.10 on iOS....   Photo albums still work fine
Seems like every version since then has brought some bugs along...  That's also why i disable Auto-Update on Apple devices - unlike Android, with Apple there's absolutely no possibility of downgrading to a previous version, so you really need to wait and watch what happens to others before updating yourself.  Same idea with the firmware.  Better safe than sorry.
2022-9-20
djiuser_sANBwSggHTHD
fans4e8f2c69 Posted at 2022-9-18 22:36
Turn off the phones VPN this worked for me
2023-11-13
fans1e25545d
Belarus
djiuser_sANBwSggHTHD Posted at 11-13 05:22
I have never used VPN on any of my device.
2023-11-13
Brad King
Same issue. Quick transfer does not work at all. None of the instructions above fix the problem, instructions in app and remote update are incorrect as the icon shown disconnects phone from aircraft.
I have turned phone off/on, cleared WiFi, changed aircraft name, changed WiFi name, logged out and in, deleted and reinstalled app, updated tv and aircraft and still does not work.
Selected photo/video and it says 0% downloading (1/2) 0b/s and then says failed to download.
2023-11-15
djiuser_PYl0Ueo0lW8D
putting the iphone on airplane mode and switching on wifi fixed it for me.
https://www.youtube.com/watch?v=NdQKtMKJmY0
2023-11-21
fans1e25545d
Belarus
I you read correcly you can find that I wrote about Android. I afraid I can not install Android on iPhone.
2023-11-21
djiuser_GAB44EMxFFgs
Hi there, I am also having the same issue. Is there an update on a resolution
2024-1-1
djiuser_qcFprFoERugy
Slovakia
I have the same problem.  My Honor 8x does not find the wifi network of the drone (DJI mini 4 pro), but for example the Samsung galaxy A41 or an old Lenovo tablet identifies the wifi network of the drone and can connect to it.  It follows from the above that the problem is with the Honor 8x mobile phone, which is apparently not supported, I don't know why. I can't find a wifi setting in the Honor 8x that would change something in this and make quick transfer (DJI Fly application) work.
2024-1-8
djiuser_9WKwPgCUieu7
Flight distance : 6778209 ft
Malaysia
Looks like we are getting same issues, but DJI not care to fix it.
Buying DJI is now depending on your luck.
2024-1-9
fans1e25545d
Belarus
It looks like there is an issue with WiFi band (frequency). Early I wrote that I was not able to switch DJI FlyApp to 2.4 only as mentioned above. However, after few times reinstalling the app and playing with it I somehow got that option available and was able to switch it to 2.4 Ghz. After that Quick Transfer started working again. Finally I switched to iPhone and all worked well. Unfortunately I was not able to test it durng past few months (with iPhone and Android) so I do not know if it works now. But somehow I got it working few months ago and I hope it still works.
2024-1-9
djiuser_OWajaHdz1m6H
Flight distance : 107976 ft
New Zealand
Hi there, every time i used quick transfer i have a problem connecting the bluetooth of my dji air 3 to my Iphone (IOS). The message pop-up “the aircraft maybe connected to other phone, restart and try again”. It was unbelievable because I have only single phone. Please help me to fix this problem. I really wanted to transfer my captured video from my aircraft to my phone. Lastly it was working perfectly fine, but now it doesn’t. Thank you
2024-1-13
DJI Tony
djiuser_OWajaHdz1m6H Posted at 1-13 21:56
Hi there. Are you using an iPhone 13 or 14? Please make sure the app is on the latest version or try reinstalling it. This has been fixed since in DJI Fly v1.9.4. app update. Have a great day.
2024-1-13
One906
Flight distance : 192592 ft
djiuser_PYl0Ueo0lW8D Posted at 2023-11-21 01:11
putting iphone in airplane mode and wifi on worked for me.
2024-2-6
Ingo Wieben
Hah! That did it! I’ve been trying to transfer files to my iPhone for yonks and I tried every possible solution and work around. Turning the phone into airplane mode did it!
That k you for the tip!!!
2024-4-26
djudge1975
I also had the same issue on iPhone and like mentioned by others I turned Airplane mode on with WIFI and it worked a treat
2024-7-10
DJI Diana
Flight distance : 2408 ft
djudge1975 Posted at 7-10 14:40
Hi there,
thank you for reaching out.
We appreciate you for keeping us posted. May we confirm if the issue persists?
Should you have any other questions, kindly message us for assistance. Thank you.
2024-7-10
Chris-9
Georgia
I have a Xiaomi K60 pro (just a one year old smartphone), and the 5Ghz band didn't appear on my Wifi list for whatever reason. Switching the fixed band to 2.4Ghz did the trick but I've then had the high interference message.
Tweaking my smartphone settings, I've been able to finally connect to the 5Ghz band and get 25-30MB/s transfer rate. I had to go to my Wifi settings > Additional Settings > Wi-Fi Region > and change "Auto" to "China" - no idea whether other options would have worked, but that was my first guess and it worked. Hopefully this will help other users.
2024-7-22
Stu.Baby
Flight distance : 52218 ft
Ingo Wieben Posted at 4-26 01:13
Same here. Airplane mode worked for me using a Tripltek tablet which otherwise could not see the Mini 2 wireless network even though the controller/FlyApp detected the presence of the drone.
2024-8-22
fans657272a2
Brilliant.  Saved me time overthinking it.  Much appreciated.
And, quick transfer is in fact QUICK!
2024-12-7
djiuser_DuhE9mhUfGCT
I’ve tried turning my phone off. I tried restarting it. I’ve tried downloading the app again multiple times I hit it. It won’t connect at all, but every now and then it does suddenly get a connection but as soon as I try to start the transfer, it tells me it has to switch and then disconnect me fix the app because it doesn’t work.
2024-12-13
djiuser_zLEEUQdE1iAX
DJI Mini 4 Pro RC, iOS 18. Latest DJI Fly app. Latest firmware on RC.
I have this same problem not able to transfer with quick transfer, tried clearing cache, resetting controller, deleting and re-adding the DJI Fly app. Tried formatting SD (suitable card) card.
Tried Restarting phone, drone and RC multiple times.
Thumbnails still show up as black boxes and quick transfer sits at 0%
I can insert SD card into laptop and then upload  to phone but prefer to be able to use quick transfer…appears this is a common problem.
Anyone have any other tips?
2024-12-28
