Swapping links between DJI FPV and Avata
1175 4 2022-9-18
BarnSwallow
Flight distance : 5076896 ft
Just got my Avata.  Went through the update of firmware for the DJI FPV and the Avata all successful.  Activated the Avata successfully.  I was thinking I could just change the link  from the FPV to the Avata by using the pair button on the goggles and doing the 4 sec press on the Controller and Avata.  No luck.  Had to go back to using the GoFly app to re-establish the link.   Is that right?  Kind of a hassle when out in the field.
2022-9-18
BarnSwallow
Looks like a firmware change is required when moving back and forth each time.  Avata->FPV  and FPV ->Avata.  Always have to go through the Fly App.
2022-9-18
DJI Wanda
Hello, there. May we know you are trying to pair the DJI Goggles 2 with DJI FPV drone?
2022-9-21
djiuser_bFT8cCxOErS3
Flight distance : 1432585 ft
I had to do same thing using the fly app and you can see that it's changing out the firmware only takes a few minutes. Would have been way nicer just to press the button on the goggles and then the remote and the Drone like you do when you first bind it up.
2022-9-28
BarnSwallow
djiuser_bFT8cCxOErS3 Posted at 9-28 12:08
See my most recent post.  My DJI FPV went beserk after reconnecting.    Related?  I have no idea.   Sending it back to DJI to have them look at it.
2022-9-29
