Brlux
Hi, I have experinces this issue 3 times now. When flying around the back yard my with my Avata. It will pause as if the pause button was pressed when it hits 20% battery, then it will fly dirrectly home at it's current altitude. I have no contorle over it untill it reaches the home point and starts to decend. I have my rth altitude set above 100ft as that is above all the obsticals in my area. But probably because of the close proximity to the home point when this happens, about 50 feet away it does not rise up to the rth altitude. I have been lucky so far and it has not colided with anything yet but it surely will at some point. I am flying with the FPV controller 2 in normal mode using goggles V2.
I believe
1, It should never attempt to fly somewhere and not accept user input.
2, You should be able to cancle a rth.
3, The low battery rth % should be user adjustable and possibly be related to your distance away from the home point.
