Mzp
Hi Your Friend,
Just regarding the part on getting a used one. If you found it on Amazon and not able to contact the actual previous user to unbind their account from this drone, you may end up getting a drone that you can't activate. I heard many stories of people buying used DJI drones on Amazon where there is no actual prior owner known and getting a drone they can barely use or can't use at all. Just 2 cents for you to be ware.
If you can get in touch with the seller , like it's on Ebay and if the price is good and seller can unbid their account from the drone, it might be worth it if you need obstacle avoidance from all directions, large battery (that is the same as on your Mini 3 Pro though), HDR video (Mini 3 Pro has it but on lower end), higher wing resistance than Mini 3 Pro, 10 bit D-log for shooting in flat color profile for HDR delivery. Also another advantage over Mini 3 Pro is the secondary zoom tele lens , but it can only shoot in normal color profile at 4k 30fps. Overall image quality and also low light shooting is far superior than Mini 3 Pro. Hope this helps in your decision. (imho if you can't contact the seller to unbind his / her prior DJI account, may not be worth the risk of getting already activated and linked to someone else's account drone).
Thanks, Mike. |
