Phantom 4 Pro- Gimbal not responding
2037 4 2022-9-19
Leo2017
The gimbal is not responding after I turn on the drone. The drone was not in a crash. When I turn it on the camera is going up and down and back facing straight down again. Also it is not responding to RC. I belleive it start happening after the firmware update. I calibrated the gimbal on Assistant 2, and calibrated IMU. Not sure what else I can do. Is it possible to get an older version of the firmware?
2022-9-19
Leo2017
2022-9-19
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm if the gimbal can perform its gimbal self-test when you turn it on? In addition, kindly please try to re-link the aircraft to the controller and check if the issue persists. You may refer to the tutorial below. Please keep us posted. Thank you.
2022-9-20
Leo2017
Thank you for your response. It looks like the linking was not the problem. I linked it anyway, following tutorials just in case. No change. Once I turn it on the gimbal is performing a self-check and goes back facing down. No funny noises and it seems to be moving smoothly.
2022-9-21
djiuser_U5dXgH7GbiUv
Flight distance : 372654 ft
Were you ever able to find a fix. I got the same thing after firmware update. Thanks
3-11 00:10
