Googles 2 Foam Padding
4116 27 2022-9-20
Woobisah
Flight distance : 1702457 ft
Is the part on the DJI website for Goggles 2 foam padding the same as what we already have, or something better?   Definitely don't want to order the same thing, even though it isn't in stock as of yet.
2022-9-20
New2Mini2
Flight distance : 3895528 ft
Yes, it is a stock replacement. I imagine there will be third party venders making them very soon though. The stock foam only seems to work for 20% of the users.
2022-9-20
frankymusik
Flight distance : 27841053 ft
New2Mini2 Posted at 9-20 06:21
... 20%...???
... less than 10%, I would guess...
2022-9-20
Bob Brown
Flight distance : 4209662 ft
I will be honest. I search daily for an aftermarket solution. The Goggles 2 faceplate is obviously for Chinese flat faces.
2022-9-20
Woobisah
Yeah I need something that has more of a cushion and not just for comfort but to push my face a bit away from the screen as I feel it is just too close and I have to search with my eyes instead of peripheral vision on the screen.
2022-9-20
The Saint
Flight distance : 5902228 ft
the aftermarket crew is pretty good and should have a solution shortly.  there are a ton of suitable aftermarket foam for the dji fpv so it's gonna happen for sure.
2022-9-20
DJI Stephen
Hello there Woobisah. Good day and thank you for reaching out. The DJI Goggles 2 Foam Padding ( https://store.dji.com/product/dj ... &from=store-nav ) found on the DJI Online Store is the same as the the one that is included on the DJI Avata Package. Thank you.
2022-9-20
djiuser_lwE3SRh9LWUl
Flight distance : 799698 ft
I can’t read anything one the bottom of the screen unless I pull the bottom away from my face I need thicker foam on the bottom of the seal
2022-9-24
JAMh
Flight distance : 4754715 ft
Mexico
I simply changed zoom to 80% and now I can see clearly all the screen.
2022-9-25
guidodg
Flight distance : 149757 ft
South Africa
JAMh Posted at 9-25 01:21
sure, that works for the drone camera feed but the stats and info remains illegible down in the bottom corners of the screen
2022-9-25
RichfromHowellNJ
Flight distance : 508255 ft
Has anyone tried these https://www.getfpv.com/dji-goggl ... Qk_EBoC-KQQAvD_BwE?  They are in stock.
2022-9-25
BOOSTDtv
RichfromHowellNJ Posted at 9-25 03:42
Has anyone tried these https://www.getfpv.com/dji-goggles-2-foam-padding.html?gclid=CjwKCAjw-L-ZBhB4EiwA76YzOa0pDOd9Sfgryzhz3kNH72xRmVSQuS6xxenKTt6V6J7ngcBkBQk_EBoC-KQQAvD_BwE?  They are in stock.
those are OEM replacements. same that comes stock.
2022-9-27
Woobisah
I wish they named these Goggles using something other than the #2.  When searching you always get tons of V2 results and it sucks sifting through them all.
2022-9-28
JAMh
Mexico
Another way is to 3D print this part that will adapt beter to your face.Will also be far away from screen, so maybe it helps to look better.
https://www.thingiverse.com/thing:5494110
2022-9-28
djiuser_Nb9v5cIT7uLk
JAMh Posted at 2022-9-28 17:23
Please tell me how do I get one to try it?
How much in AUD.
Is it designed for DJI Goggles 2 ?
From the picture it is hard to tell but it looks like is fitted to the top of the goggle, I need it to fit at the bottom.
If is design for DJI goggle 2 , and can be fitted to the bottom of the goggles, and make the goggles sit further away from my face at the bottom of the goggles?  If yes, that is exactly what I need, as I can not see the information displayed in the corners of the screen clearly.
How does one attach it to the goggles? That is, does, it fit between the OEM padding and the goggle casing? What holds it in place?
2023-4-16
Robino
Slovakia
home made custom mask 25#
2023-4-16
Robino Posted at 4-16 23:27
https://youtu.be/exu92UsEOxo
Hi Robino, I have sent you a personal Message. I am very keen to know how I can get some Modified Padding. Regards Brad.
2023-4-17
SeehawerB
Flight distance : 5414203 ft
My nose is too long and wide for the Goggles 2. That's the main problem why I can't see the edges of the screens at all. At least there is a better pad on the market which I bought. It's much softer. Will not change the problem with the nose, but still makes wearing the Goggles 2 a lot better for me.
https://de.aliexpress.com/item/1 ... atewayAdapt=glo2deu
It's also available via Amazon, but not so cheap as directly from China.
The nose problem cannot be solved without changing the shape of the plastic housing of the Goggles. Yes, it is made for "flatter faces", not really a good idea for a global market product.
2023-4-17
Mini-G
Flight distance : 673862 ft
DJI Stephen Posted at 2022-9-20 19:25
Hello there Woobisah. Good day and thank you for reaching out. The DJI Goggles 2 Foam Padding ( https://store.dji.com/product/dji-goggels-2-foam-padding?set_region=US&from=store-nav ) found on the DJI Online Store is the same as the the one that is included on the DJI Avata Package. Thank you.
It would be nice if there was short sentence that says “note: this is the a replacement part, similar to the one included”
2023-4-18
The Jack
Flight distance : 32326 ft
2023-4-18
fans9bdfb4fe
https://m.dji.com/de/product/dji-goggles-foam-padding-soft-fit
2023-4-22
The Saint
fans9bdfb4fe Posted at 4-22 09:42
it's out of stock but you can setup a reminder here:  https://store.dji.com/product/dji-goggles-foam-padding-soft-fit
2023-4-22
Elephant Apocalypse
Flight distance : 6336594 ft
well apparently these FPV googles in general doesn't fit asian people LOL or big nose people or just 90% DIY and inching along on good fitmet to see all the MSP display like the V2 goggles, starting to regret getting the goggles 2
2023-4-22
Robino
Slovakia
I found this yesterday https://shop.iflight-rc.com/DJI- ... oam-Padding-Pro1937[/url]
2023-4-23
Robino
Slovakia
2023-5-18
Koolada
Flight distance : 877999 ft
Not sure if they send to other Countrys but for German users that dont want to get suffocated by the Nose part this could be the Final sollution:
Confort Foam für DJI Goggles 2
Hope it will be avayble soon, just hope the Padding is not too less.
Maybe someone got one already and can tell something about the fitting? Really dont wanna spend another 17,95 and still got not sollution for this.
2023-5-19
Koolada
Robino Posted at 4-23 10:32
I found this yesterday [url=https://shop.iflight-rc.com/DJI-Goggles-2-Sponge-Foam-Padding-Pro1937https://shop.iflight-rc.com/DJI- ... oam-Padding-Pro1937]https://shop.iflight-rc.com/DJI-Goggles-2-Sponge-Foam-Padding-Pro1937https://shop.iflight-rc.com/DJI- ... oam-Padding-Pro1937[/url][/url]
[view_image]
Looks alot like
Which I use for now, its a much better experience than the stock ones but still not perfect, still got my Nose Squezzed together a bit.
What is your rating for the Iflight one and which Version did you Order? I need to order some stuff from Iflight so i could just Put it in if its really good.
2023-5-19
Robino
Slovakia
Koolada Posted at 5-19 00:14
Looks alot like
I tried all paddings available on the market and this one fits the best. https://www.aliexpress.com/item/ ... n.16.48db1802fqWYAH
TYPE B Narrow. Anyway, it is not 100% perfect.
2023-5-19
