h264 vs h265, does any difference exist?
5294 13 2022-9-23
mart_drone
Hi,
When I record in h264/h265 the file sizes are basically the same, and so is the quality (to me).
Is it the case that at 150mbps h264 is more than enough for 4k/60, and such we are in placebo territory.
Thanks
2022-9-23
The Saint
Flight distance : 5902228 ft
i dunno, the files size really should be smaller.  how's the difference when you work them in post?
2022-9-23
Labroides
Flight distance : 9991457 ft
https://www.boxcast.com/blog/hev ... hats-the-difference
2022-9-23
frankymusik
Flight distance : 27841053 ft
Labroides Posted at 9-23 18:04
https://www.boxcast.com/blog/hevc-h.265-vs.-h.264-avc-whats-the-difference
... a very meaningful link!
Thank you...
2022-9-23
mart_drone
That links suggests:
4K h264 needs 32 mbps
4k h265 needs 15 mbps
DJI M3P used 150mbps for both! Which would seem to be massive overkill.
2022-9-24
DowntownRDB
Flight distance : 1722 ft
Very informative article Labroides.  Thanks for sharing.
2022-9-24
Akila2
Flight distance : 178950 ft
Israel
that is because if they would aim for smaller mbps, they will need to embrace much higher QF and that take a lot more processing power. even on PC 8 Core CPU it takes a lot of power to process at 100% CPU utilization..
2022-9-24
mart_drone
Akila2 Posted at 9-24 10:29
Makes sense, thanks.
2022-9-24
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Kindly please refer to the information below with regards to the Frame rate, coding format, and video bitrate of each video resolution for the DJI Mini 3 Pro for your future reference. Hope this helps. Thank you for your valued support.
2022-9-24
Akila2
Israel
yeah, that we know, but the original poster question was, why they using such High Mbps? h.265 clearly should provide on a much lower Mbps then an h.264 with the same image quality.
Also they not mentioning what QF they are using or any other h.265 parameters. buttom line , there is no real added value using h.265 (vs h.264) on the mini 3 , as they are not using the features and compression level HVEC provides compare to AVC (h.264).
you better off using h.264 as it is compatable with many more playback devices then, h.265 and draw less power playing/decoding.
2022-9-30
Bashy
Flight distance : 2354357 ft
Yeah, it does not make much sense. The quality should be the same but it should be using a much smaller bitrate thus producing a much smaller file, that's the whole idea of h.265, same quality at a lower bitrate for faster upload and or broadcast, so why DJI is using the same bitrate for h.265 compared to h.264 throughout the whole range of quality and fps is beyond my comprehension.
Although, what DJI is saying is that recording at 48, 50 or 60fps in 4k is possible due to h.265. Has anyone tried 4k at 60fps in h.264? I suspect it's not possible, but at 150 bitrate, that's file is gonna huge
I also suspect that the battery will not last as long and also perhaps the AC is more susceptible to overheating when using h.265 due to higher CPU usage.
2022-9-30
mart_drone
I have done a number of tests, 4k even when viewed on a 43" screen at 2x zoom, I can see no difference in H264 v H265 at 150mbps.
2022-10-1
Bashy
mart_drone Posted at 10-1 14:33
You probably won't, 4k is 4k after all, the difference should be seen in the file size but as it cannot do 150mbps in h.264 you will never know if there is a difference in file size.
2022-10-1
Geo_Drone
Flight distance : 2676129 ft
Romania
Yes, you will see differences in H265 vs H264, as at high res like 4K all H265 will give you a plus of details.
Is about ho compression works and how the blocks of image are built.
Is a very long discussion, just search for my post related to H264 vs H265, you will see that at zoom 4X you get +20% more details in H265 vs H264.
Cheers.
2022-10-3
