Audience Mode
6509 15 2022-9-24
fans49a4213f
Hello yall i want to know if i can use my v2 goggles to watch while someone is flying the Avata with the new Goggles 2?
2022-9-24
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Yes, you may connect your DJI FPV Goggles V2 to your DJI Avata for audience mode, however, you need to have all your components, especially the FPV Goggles v2 to have the latest firmware to avoid issues. In addition, you need to change the mode to "DJI AVATA" in the DJI FPV Goggles V2 menu. Hope this helps. Thank you for your valued support.
2022-9-25
fans49a4213f
DJI Paladin Posted at 9-25 03:27
Paladin,
      Thx for the info ill give it a try also thx for the quick response!!
2022-9-25
DJI Paladin
fans49a4213f Posted at 9-25 06:50
Paladin,
It's always my pleasure to help. Should you have other inquiries or concerns, please don't hesitate to reach us. Thank you for always choosing DJI!
2022-9-26
fans6e955622
Observing this post and would like specific clarification.
Someone can be flying their Avata with Goggles 2.  A second person can observe the flight using their V2 goggles.
Me sign you can connect both Goggles 2 and Goggles V2 to the Avata at the same time?  It doesn’t have to be the same version of goggle?
Asking because this is something I am researching before buying an Avata.
Thanks.
2022-9-30
DJI Paladin
fans6e955622 Posted at 9-30 11:03
Thank you for reaching out. Just to clarify, your concern is if the Two (2) DJI Goggles 2 or 2 DJI FPV Goggles V2 can be connected to the DJI Avata for Pilot and Audience mode. Please keep us posted. Thank you.
2022-10-2
crtaustralia
Hi, is it possible to view audience mode on a device other than goggles, such as a phone or PC. I know I can view the stream in the DJI Fly app, but I want to be able to do it wirelessly.
2022-11-18
square_wire
Hi, can I fly the avata on goggles 2 and have the audience mode on another pair of goggles 2?
2022-12-20
SkyMotionDrones
Flight distance : 989019 ft
My understanding is you can fly the Avata with the goggles 2 and Audience on a set of Goggle 2 or Goggles v2.   Then you can connect the Audience Goggles to the Smart Controller and have that output a HDMI signal.....  Or build a Cosmostreamer.
https://cosmostreamer.com/products/djiavata/
2023-4-1
scoble08
Flight distance : 4327592 ft
DJI Paladin Posted at 2022-9-25 03:27
Hello.
Can I fly the avata on goggles 2 and have the audience mode on a pair of goggles Integra, or vice versa?
If so, how?
2023-4-1
DJI Paladin
scoble08 Posted at 4-1 14:20
Hello.
If so, how?
Hi there. Thank you for reaching out. Yes, DJI goggles Integra have audience mode, settings location: Goggles integra menu> Settings> Transmission> Audience mode; and Goggles integra can be a Goggles 2 audience when Goggles 2 is turned on broadcast mode. Hope this helps. Thank you for your valued support.
2023-4-3
djiuser_1IoV43V5RNwS
Flight distance : 176526 ft
Poland
With the recent compatibility upgrade googles can be paired with dji mini 3 pro, however, its lacking the audience mode. Is there any plan to implement that feature into mini 3 pro? Is it technically possible at all?
Thanks
2023-5-13
Salvador BALCELLS TALAVERA
Flight distance : 493976 ft
Please important, mini pro 3 with googles integra, dont have mode audience... i bought two googles for share eith two googles ( how avata this function is aviable and work good) Please, update firmware for activate mode audience?
If it is not possible for phisics mavic , another idea: use second googles integra via cable for view primary googles, same function phone-googles for view two persons, but via googles the immersive view is totally,, please , one solution for share mavic minibpro with two googles integra... via audience or via cable
2023-5-27
DJI Tony
Salvador BALCELLS TALAVERA Posted at 5-27 09:05
Hi there. Thanks for reaching out. We're sorry, but both methods are currently not support. But rest assured that your feedback will be voiced out to the DJI Developers for attention. We appreciate your understanding and support.
2023-5-28
djiuser_oem3ZvfXmUnI
Argentina
Hello how are you? I need to know if my flight with Avata can be seen by many people through several dronemask2 connected to my Integra goggles. thank you
4-6 10:10
DJI Paladin
djiuser_oem3ZvfXmUnI Posted at 4-6 10:10
Hi there. Thank you for reaching out. We haven't tested the connection of this Goggles (dronemask 2) therefore we cannot guarantee a perfect connection with our product. Please note that the DJI Avata can only be connected via DJI Goggles like DJI Goggles 2, DJI Goggles Integra, and DJI FPV Goggles V2. Should you have other inquiries, feel free to contact us. We appreciate your understanding and support.
4-6 20:35
