Smart Controller Waypoints Shows All White Screen
1085 7 2022-9-24
Lokinator
Hi
Went to use waypoints today and got a error message and the google map is all white. No detail. I can change terrains etc but no dice. I notices the Waypoints on the Homescreen has a "?"  but does seem to react when I select it. Im using a Mavic Pro 2.
Any ideas? Thanks in advance for your advice and help
Bob
2022-9-24
Mobilehomer
Flight distance : 18150351 ft
Internet connection?
2022-9-24
Lokinator
I was out in the field and I am home now still the same problem total white screen its like no Google maps?
2022-9-24
Lokinator
I also have the regular non smart controller. I tried to hook that up but I guess the DJI Go Fly app isnt supported in the Play store anymore. I had no idea. So now I am stuck between the Smart controller not working for waypoints and no software to run on my phone and the non smart controller. I wanted to see if it was a smart controller issue. Ugh. I have had a heck of a time with the smart controller ever since I got it.
2022-9-24
Mobilehomer
Go here to download - https://www.dji.com/downloads/djiapp/dji-go-4
2022-9-24
Lokinator
Thank you very much. Got the app working on the non smart controller/phone. Still get the error message the message says "required conditions not met. APAS is temporarily disabled". I was able to get litchi to open as well and it works fine including waypoint settings. So thinking maybe something with google maps?
2022-9-24
Lokinator
Ok wont connect to my home but got it to tether to my phone hotspot....I got it to work and the maps to show up. I was downtown Chicago when this happened,,,no way I wasnt near satelites....maybe Im ignorant but dont remember needing to be tethered/connected to my phone to do waypoints. Do you need to be connected to the internet to do waypoints? I was just trying to do a impromptu flight plan only going 20 feet back and 30 feet up?? Regardless thank you very much for your help
2022-9-24
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused.  Can you please confirm if you still experienced an issue with your unit when doing Waypoints? In addition, we strongly recommend performing this said feature in a location wherein it has a strong GPS signal away from any possible interference to avoid issues. Thank you for your valued support.
2022-9-25
