DJI Tello Update Firmware Problem solved
19920 13 2022-9-26
drones_bulgaria
Bulgaria
I had really a problem with my Tello and Ryze Support ... basically cut me out. So I had to search for a solution to update my drone due to image stabilization problems with the default one. I tried many times with the Tello app to update.. nothing happened. It always says It was with Latest firmware. So DJI Support told me nothing they can do and it was due to an Incompatible android phone. That was not true, because I tried at least 5 different phones, newer ones that ware IN the list of compatible devices for the app and the drone. So I found out that not only the firmware, but the App was problematic too.
And I found this in another forum:
1. Charge the battery to 100%
2. Install Tello App v.1.1.1
3. Hold the Power Button on the drone WITHOUT battery in it, then connect it to a PC/Laptop USB or a charger without letting the power button, keep it holding and insert the battery in the drone, when a green led turns off release the Power button. Then a pulsing red light will start.
4. Connect the Tello drone to your phone and go to Update setting, Download the Firmware ( it will want to connect to WiFi Network with Internet, do it without turning off the drone), after downloading finished, connect with Tello again and click the Update button, wait until the end, when a Blue light starts flashing wait for another 3-4 minutes and then restart with charging cable pulled off the drone.
That's it. I hope it will help someone
P.S. For some Reason in Tello app shows still the old version but on the update menu it says that I have downloaded v02.05.01.19 - Date 2022.05.07
2022-9-26
drones_bulgaria
Bulgaria
Didn't knew about this one too. So pretty much is the same but doing it without the need to connect it to the charger. :
2022-9-26
Wimov
Croatia
I keep getting upgrade error restart app.. i tried using mobile data to download since Tello is taking the wifi, but not working. Any help?
2022-10-8
drones_bulgaria
Bulgaria
When Tello app props to download the update, go to wifi and choose your wifi with internet. after download tello app will tell you to connect the drone so you can then change again to Tello's Wifi
2022-10-8
ro_walker
Brazil
Very frustrating!
2022-10-30
drones_bulgaria
Bulgaria
Unfortunately. I don't understand why Ryze are like ignoring the existence of this drone
2022-10-30
ro_walker
Brazil
drones_bulgaria Posted at 10-30 22:51
2022-10-31
galli.tommasohotmail.it
Flight distance : 36447 ft
Thank you! I’ve finally solved the firmware upgrading problem
2023-9-24
Hajnall
Hungary
Hi, Unfortunatelly, this method changed downgraded my latest firmver (v01.04.92.01) to v01.04.91.01 Can I update again for 92.01? Automatically not works, because when I try, then get back the firmware is the latest version message.
2023-12-17
drones_bulgaria
Bulgaria
Hajnall Posted at 12-17 07:07
Please read carefully!
2023-12-19
DJI Paladin
Flight distance : 318 ft
Hi there. We do apologize if you are having issues with your unit. For further assistance, we highly recommend that you contact Ryze Robotics support using this link https://www.ryzerobotics.com/support . Thank you for your understanding.
2023-12-19
László Hajnal
Hungary
DJI Paladin Posted at 12-19 20:12
I tried to reach the support, but not possible. The email messages bounce back from ryzerobotics, but I tried more contact address too.
2023-12-20
DJI Paladin
László Hajnal Posted at 12-20 22:23
Hi there. Thank you for reaching out. Please confirm what specific issue you experienced on your Tello drone so we can assist you further. Please keep us posted. Thank you.
2023-12-22
djiuser_2mmDQv9AYf3V
Happy New Year! Is there any news about the possibility for the Tello to fly to A1? I am in possession of an A1-A3 license, D-Flight registration and insurance. For my use I'm fine with this little guy.
DJI has not been able to update the User Manual to include the MTOM/MTOW. What will happen to the Tello?
Thank you very much for the answer and patience...
Cosimo
2024-1-8
