Lost my Avata adapter (single charge)
1900 7 2022-9-27
fans93492ae5
Flight distance : 486503 ft
Brazil
Hi,
I've lost my original Avata adapter (single charge).
I tried connecting a ~16V power supply to the battery pins directly, like I already did with other DJI drone batteries in the past, but with the Avata I get the "LED4 | blinks four times per second | Non-DJI adapter" error.
https://youtube.com/shorts/ozaLuo6Et9k?feature=share
Is it possible to bypass this error and charge the battery without the adapter?
Please DJI enable USB-C charging on the drone, like the MINI 3 and MAVIC 3.
2022-9-27
DJI Stephen
Hello there. Thank you for reaching out and for giving out these information. I will forward these information to the designated DJI Department for attention. Thank you.
2022-9-28
frankymusik
Flight distance : 27841053 ft
Sooner or later you will need the fly more kit and then everything will be settled...
2022-9-28
Ken-W
Flight distance : 394626 ft
United Arab Emirates
frankymusik Posted at 9-28 23:04
If and when the Fly More kit is available - it's not available in all countries...yet ;)
2022-9-28
frankymusik
Ken-W Posted at 9-28 23:59
... because of the built-in "intelligence" that ensures that the batteries work for a very long time (e.g. do not "bloat up"), it will not be possible to charge them correctly without the right accessories...
2022-9-29
fans93492ae5
Brazil
frankymusik Posted at 9-29 05:01
Hi! The "intelligence" is inside the battery. Load balancing, etc, all inside the battery. The adapter is just a voltage converter + authorizer.
2022-9-29
frankymusik
fans93492ae5 Posted at 9-29 06:00
... the interaction will be important...
2022-9-29
Bob Brown
Flight distance : 4209662 ft
Contact DJI Support to buy another adapter. There really is no substitute.
2022-9-29
