ICM Photography
1736 8 2022-9-29
visionandlight
Flight distance : 18615 ft
Hi all.
Does anyone know if you can do ICM or Intentional Camera Movement Photography with a drone?
I want to be able to lock the gimbal in place and capture images while  the drone is moving forwards/backwards, up/down so as to get smeared  images.
I have a P4P Pro.
Tia.
Andrew
2022-9-29
Labroides
Flight distance : 9991457 ft
Of course you can.
Whether you get anything worthwhile is up to you and a little luck.
2022-9-30
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Hope that you could get the best recommendation from our fellow DJI Pilots here that already tried this type of shot. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2022-9-30
visionandlight
Labroides Posted at 9-30 00:30
Of course you can.
That's exactly the sort of look I am after.  Can you something like that while the drone is ascending as well?
Did you lock the gimbal? If so, how?
Regards
Andrew
2022-10-3
Labroides
visionandlight Posted at 10-3 02:52
Regards
You can shoot at a slow shutter speed and move the drone any way you want.
Up, down, left, right, spinning around ....
You can't "lock" the gimbal, but it should hold position anyway.
2022-10-3
visionandlight
Labroides Posted at 10-3 04:16
Thank You, I appreciate the reply.
2022-10-3
MavicDroneflyer
Flight distance : 363064 ft
Jersey
Please let us know how you get on, I’m interested  in trying out ‘In the round’ Pep Ventosa technique using drones
2022-10-14
visionandlight
MavicDroneflyer Posted at 10-14 04:04
Well I have tried but the image still comes out the same, and only slightly blurred and over exposed. I have a ND64 on but it doesn't seem to make much difference. I'll keep trying and let you know if anything works.
2022-10-19
ro_walker
Brazil
Stored in app as long as they are not deleted.
2022-10-25
