Compatibility of Ronin RS 3 Pro with Panasonic Lumix S1
2797 8 2022-9-30
myblank
Hello,
I need to know, when will Ronin RS 3 Pro be compatible with Panasonic Lumix S1? The S1H and S5 are supported. The S1 is also a professional camera.
Unfortunetly it is not listed in the support list of Ronin RS 3 Pro. But instead the Ronin RS 2 is supporting Lumix S1.
Thanks for your support.
Best regards
Chris
2022-9-30
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. It shows here that the Panasonic Lumix S1 is not listed on our recommended Camera and Lens for the DJI RS 3 Pro. You may want to check the list using the link below. Thank you for your understanding and support.
https://www.dji.com/support/compatibility
2022-10-1
myblank
DJI Paladin Posted at 10-1 23:28
Thank you for your information. Unfortunetly this was not the answer to my question.
I already know the list which cameras are supported by RS 3 Pro and that the Lumix S1 is not supported.
My question is: when will the Lumix S1 be supported by RS 3 Pro? Or will it never be supported?
The Lumix S1 is a professional camera for videographs and it is not understandable why DJI does not support this model.
Thanks for your feedback, when RS 3 Pro will support Lumix S1 as well because this is elementary for me whether I buy the RS 3 Pro or not.
2022-10-1
DJI Paladin
myblank Posted at 10-1 23:42
Thank you for your response. We don't have any information if this camera will be compatible with the DJI RS 3 Pro. However, I will take this as a suggestion of yours and will forward it to our designated team for attention. Thank you for your patience and understanding.
2022-10-2
myblank
DJI Paladin Posted at 10-2 21:46
Thank you very much!
2022-10-2
DJI Paladin
myblank Posted at 10-2 23:33
You are very much welcome. Thank you for always choosing DJI!
2022-10-4
myblank
Hello again,
the Ronin RS 3 Pro is now officially compatible with the Panasonic Lumix S1, see: https://www.dji.com/de/support/compatibility/rs-3-pro/s1
BUT: Bluetooth is still not working. Why?!
Furthermore I need to know, if the following USB-C to USB-C cable makes it possible that the Lumix S1 can be controlled by Ronin RS 3 Pro: https://www.camforpro.com/dji-rs-l-foermiges-multi-kamera-control-cable-usb-c/
The compatibility list mentions that the functionality has been tested with "Camera Control Cable: ①USB-C TO USB-C".
Thank you in advance for your support.
Best regards
Chris
2023-6-6
SkywalkerZW
Zimbabwe
myblank Posted at 2023-6-6 07:13
Hello again,
Hi Chris, hope you are great. I just wanted to find out whether you managed to find a way around this? I purchased a RS3 Pro to days ago and I'm failing to access my S1 via the gimbal both on USB and Bluetooth.
Kind Regards, Nkosi
2-17 07:49
Shannendreija
Hi Nkosi,
I didn‘t manage to connect the S1 via Bluetooth with the RS 3. But I changed the camera model some months later and bought the new S5 II. This camera can be connected to the RS 3 without any problems.
Best regards
Chris
2-17 11:32
