Non DJI battery error FPV ?
5579 18 2022-9-30
Snowbird147_NS
Flight distance : 423553 ft
I purchased the FPV fly more  battery kit and charged them up. I flew with the original battery today,  but when I changed to one from the kit, there was an error on my screen saying non DJI battery and would not let me take off. The second battery from the kit did the same thing..
The box the kit came in is authentic - at least it looks like that to me..
Anyone else have this issue? Hoping for some suggestions before contacting support etc..
Thanks
2022-9-30
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm how many batteries are affected? Can you please try the working battery first then try again the one that experiences the issue then check if the issue persists? If yes, kindly please try to wipe the metal contact pins on the battery or the aircraft with isopropyl alcohol (concentration >75%) then check if there are some changes. Please keep us posted. Thank you.
2022-10-1
Snowbird147_NS
I will do that and report back - both of the new batteries from the fly more kit were doing this.  Thank you.
2022-10-1
Snowbird147_NS
I have cleaned the terminals as requested and no change - it still says non-DJI battery.
2022-10-1
Snowbird147_NS
I have connected to DJI assist 2 and for firmware it says it cannot load Firmware list - I have updated the firmware on the original battery previously.
2022-10-1
DowntownRDB
Flight distance : 1722 ft
Did you order the kit directly from DJI, a local retailer or an online retailer?
2022-10-1
Snowbird147_NS
DowntownRDB Posted at 10-1 08:01
Was thru an auction site actually..  Update: DJI support came through for me - I sent them to their repair centre and they have repaired/ replaced them no charge.
2022-10-10
DowntownRDB
Snowbird147_NS Posted at 10-10 06:08
That's great news to hear that DJI came through.
2022-10-11
djiuser_KnzDVJlY12hk
I’m having same issue I purchased thru offer up can someone help
2022-11-11
Snowbird147_NS
Suggest you contact DJI support.. they came through for me..
2022-11-11
DJI Tony
djiuser_KnzDVJlY12hk Posted at 11-11 10:50
Hi there. Thank you for reaching out and we are sorry to read that you are experiencing the same issues. If you have tried the suggestions from DJI Paladin and the error remains, you may consider sending the batteries and the drone (in case the same error appears on all batteries) back for further testing. We recommend that you reach out to our Customer Support first as mentioned by Snowbird147_NS in the previous comment above for further details about the warranty and the whole process. You may contact them through this link: {https://www.dji.com/support}. If your drone falls under a USA version, you also have an option to directly submit an online repair request through this link: {https://repair.dji.com/repair/index}. Additionally, please note that warranty service can be applied depending on the warranty status and the version of the product. Should you have any concerns or inquiries, please do not hesitate to reach us here at DJI Forum. Thank you for your continued support.
2022-11-11
djiuser_T589OzdeNZDc
DJI Paladin Posted at 10-1 02:31
I am also having the same issue.just bought the overly complicated broken piece of garbage today and signed a waiver that if i need to return it (to bestbuy) its a 15% restocking fee. which after thepurchase of the drone and motion controller, im out nearly 180 dollars because DJI sent a bad product. absolutely infuriating. also,their app isnt on the google play store and doesnt work on my phone. this company needs alot ofwork and is trying to pass off experimental garbage as quality products. zero star review anwhere i can leave one. makes me sik i have to give these clowns 180 dollars to return their broke. crap to them.
2022-12-26
djiuser_qczGCDH6PMBN
Saudi Arabia
djiuser_T589OzdeNZDc Posted at 2022-12-26 19:33
I’m having the same issue. I bought it from BestBuy and I’m using the battery that’s actually come with it in the same box. It’s telling me it’s non DJI battery
2023-1-18
Saudi Arabia
2023-1-18
TheGodFather78
I bought the DJI FPV Drone and Fly More kit in Nov. 2022. Since I have been using 3 batteries and no problems. I bought a fourth battery last week from Amazon, but whenever I plug it into the Drone, I receive the error message, in the goggles, Non-DJI Battery, but clearly it is… I can see the cameras stream out of the goggles but i cannot take off. Clearly, it's a software issue, DJI tells me that it is very rare.
Also I have a Suggestion for the FPV System that everyone would love to see... And that is Could you take the Flght info that you see in the goggle that is missing from the phone view and add that info... The height, distince and battery life info the the phones screen...
thank you
TheGodFather78
2023-2-10
domo
Flight distance : 769239 ft
DJI Paladin Posted at 2022-10-1 02:31
Hi i have also 2 extended pro batteries for mini 4 and they will not update and i can not take off do too an error stating that these are not dji batteries, these are $100 batteries and are you telling me inam stuck with these batteries becouse of greed they worked perfectly until this new firmware update
4-24 07:46
domo
DowntownRDB Posted at 2022-10-11 03:53
This is really not cool
4-24 08:01
domo
All batteries work except for my extended life batteries. My pro batteries they will not update in the throne. Literally cannot even take off, says 90JI battery. I've cleaned everything. It's none of that. It's the non d j I battery issue
4-24 08:02
DJI Paladin
domo@everything Posted at 4-24 07:46
Hi there. Thank you for reaching out and we're sorry for the trouble. Please download the DJI Assistant 2 software using the link below and insert the battery with an issue one by one on the aircraft then update/refresh the firmware. Please keep us posted with the result after doing the firmware update via the Assistant 2 software. I appreciate your cooperation.
https://www.dji.com/global/downl ... sumer-drones-series
4-25 23:13
