After crash..vision sensor error
1433 16 2022-10-2
RiChaDo
Flight distance : 1219715 ft
Hi I recently had a crash it was just a branch but the avata gave me impact detected but instead of correcting it it gave full throttle and nosediving into a three and battery got released so I send the battery back to dji to fix it but after buying a new battery I wanted to check if everything was alright and it's still able to fly..only thing is I get sensor error please contact dji.
I just got this drone a week and already regretting this thing...
Do I need to send it? can I use same case number for my battery repair? is it fixable myself?
2022-10-2
DJI Thor
Flight distance : 13602 ft
Hi, there. Sorry for your inconvenience. You may try to restart the drone and wait for a while then restart it to see if it issue still persists. If yes, you may need to send it back for further testing. Thank you.
2022-10-2
RiChaDo
DJI Thor Posted at 10-2 03:32
I did that but no change! I did try calibrating the vision sensor on the pc but it just hangs keeps on loading... also cant see any damage on the sensors
2022-10-2
RiChaDo
small update.  vision sensor works in normal & sportmode but can't seem to get rid of that message
2022-10-2
DJI Wanda
RiChaDo Posted at 10-2 10:08
Hello, there. As DJI Thor said, we would recommend you send it back for repair if the issue persists. You may need to submit a new repair request.
Here is the link: https://repair.dji.com/repair/index
2022-10-2
Bob Brown
Flight distance : 4209662 ft
Try connecting it to PC and do a "Refresh" on the firmware. Then try to recalibrate the vision sensor.
This is usually my "hail mary" before I would send it back. ~ reflashing.
2022-10-3
RiChaDo
Bob Brown Posted at 10-3 09:39
I did that firmware refresh but when I want to calibrate the sensors afterwards It wont connect to start calibration keeps on loading
2022-10-3
Bob Brown
RiChaDo Posted at 10-3 11:39
Not sure what you are connecting, but if a cable is involved try a different cable. Otherwise, it may be time to contact support/repair for service for damaged electronics.
2022-10-4
RiChaDo
I will give it another chance calibrating if not ill send it
2022-10-4
fans97153237
Ive had this and the flatcable of the connector came lose. checked it by removing the vision sensor
2022-10-5
RiChaDo
fans97153237 Posted at 10-5 03:57
Mine still connected and sensors work it still gives me info if I'm flying low it's just that error that doesn't go away
2022-10-5
Waden
Flight distance : 192661 ft
Switzerland
Did you switch ON the drone battery before calibrating ?
2022-10-5
RiChaDo
Waden Posted at 10-5 05:31
I did and with other cable I got calibration screen but it didn't do nothing sensors give a x and do see sensor light flickering
2022-10-5
djiuser_zSFa3G8YvjlF
Any update on this?
2022-12-23
RiChaDo
I needed to send it to DJI.
2022-12-24
MAF178
Kuwait
RiChaDo Posted at 12-24 03:43
you will fix the issue with calibrating the vision sensors .. i noticed you need to calibrate the vision sensor after every crash
2022-12-24
RiChaDo
MAF178 Posted at 12-24 13:50
That didn't help anymore tried that first thing. My crash had a impact on frame...etc
2022-12-24
