Cracked props, when to change
2773 13 2022-10-2
mart_drone
Hi,
So I have gained some damage to one of the blades, does this warrant swopping the blade?
If I do swap, should I swap all or just one?
Thirdly, is it a good idea to use locktite?
Thanks
Mart
2022-10-2
UweE
Flight distance : 1016775 ft
only the slightest damage can cause problems! Change it, but always a complete pair
2022-10-2
Mobilehomer
Flight distance : 18150351 ft
Before even trying, get a proper #ooo PH screwdriver.
2022-10-2
Blériot53
Flight distance : 6188465 ft
Change them, in pairs. Even slight damage can progress to breakage. Don't risk it for a few quid.
2022-10-2
davidy61
Flight distance : 57037 ft
I think the screws that come with the new props have "locktite" on them already
2022-10-2
TonyPHX
Flight distance : 11229610 ft
They are cheap.  Change em out.
2022-10-2
DJI Stephen
Hello there Mart. Thank you for reaching out and for giving out these information. Just a reminder that before each flight, it is necessary to check your DJI Drone's propellers for cracks, wear, warp, corrosion, and damages. If any of these conditions are present, the DJI propellers should be replaced at once. Damaged propellers can lead to unwanted incident when flying your DJI Mini 3 Pro. Thank you and fly safe always.
2022-10-2
DAFlys
+1 change the props and use the new screws that come with them,  dont be tempted to reuse the old screws.
2022-10-2
chillibadger
Flight distance : 233064 ft
DAFlys Posted at 10-2 22:27
If they came out ok (screw head not mashed) and you have your own loctite is there any reason not to re use?
2022-10-2
RogerLswe
Sweden
chillibadger Posted at 10-2 22:36
Don't reuse! There is no need to save old screws.
2022-10-3
DAFlys
For one I doubt most people have the right loctite abe the new props come with them anyway.
2022-10-3
mart_drone
Thanks. So I changed all of them to be on the safe side, and I am 200+ flights!
However, why does each pair come with 3 screws when only two are needed!
2022-10-3
chillibadger
mart_drone Posted at 10-3 01:22
just in case you drop one in the grass at the flying location
2022-10-3
DowntownRDB
Flight distance : 1722 ft
My guess is because the screws are so small you  might drop and lose one.  Easy to do if you are on site and they fall in the grass.
2022-10-3
