Geo_Drone
Flight distance : 2676129 ft
Romania
DJI Paladin Posted at 10-3 23:26
Hi there. Thank you for reaching out and we're sorry for the trouble. You may try to uninstall and reinstall the DJI Fly app on your mobile device and see if the issue persists. We have noticed that the AirSense prompt in previous versions was too sensitive. For example, when a civil aircraft flies by at 1 km above the drone, a prompt will be given. As such, to ensure safety, we adjusted the AirSense function in v01.00.05.00. Please rest assured when you use your product. If you need to confirm whether the AirSense function is normal, please go to the app’s Map, and tap the aircraft icon to adjust the level of potential collision risks as required. Hope this helps. Thank you for your valued support.
Hi Paladin. On new RC was working OK....now...what you say is that is giving me a warning as is super sensitive at 1 km....I prefer a warning at 5 km, as the speed of a plane is s big that I do not even have time to react in 1 km distance...also a chopper with transponder will be not enough time to lower the drone if is at 1 km distance...
Start flying this drones guys...not just talk from your chairs inside an office.... |
