Two separate images in Goggles 2
6089 18 2022-10-4
SYC
Flight distance : 63114 ft
I recently activated my Avata Pro-view Combo but found that the left eye image and right eye image in Goggles 2 stayed as separate images, with one higher than the other.  I tried moving and turning the diopter knobs but the two images still did not combine to one.  Is this because the Goggles 2 which I got is faulty?
For your information, I drive car without glasses but need reading glasses when working on computer.
2022-10-4
DJI Stephen
Hello there SYC. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please post a sample photo showing the issue for us to be able to see and can assist you. Thank you.
2022-10-4
SYC
DJI Stephen Posted at 10-4 00:32
Hi Stephen, please advise me how I can possibly produce a photo showing the issue that the right eye image and the left eye image of Goggles 2 cannot combine to a single image.
2022-10-4
DJI Wanda
Hello, there. Sorry for your inconvenience. Since it may be difficult to confirm your issue remotely, would you mind sending it back for further diagnosis? You are advised to contact our support and create a case for you. Here is the link: https://www.dji.com/support/prod ... ite&from=footer Thanks for your understanding.
2022-10-5
SYC
DJI Wanda Posted at 10-5 04:30
Hello, there. Sorry for your inconvenience. Since it may be difficult to confirm your issue remotely, would you mind sending it back for further diagnosis? You are advised to contact our support and create a case for you. Here is the link: https://www.dji.com/support/product?site=brandsite&from=footer Thanks for your understanding.
Thank you for your reply.  I have found a way to overcome the problem.
2022-10-11
DJI Wanda
SYC Posted at 10-11 22:51
Then, would you mind telling us the method you used?
2022-10-12
SYC
DJI Wanda Posted at 10-12 00:43
Put one eye on duty and the other eye on standby.
2022-10-12
DJI Wanda
SYC Posted at 10-12 01:09
Sir. We are not sure about the method but for your futural experience when using DJI Avata. We would recommend you send it back. Thanks for your understanding. If there is anything we can help with, please let us know.
2022-10-12
djiuser_axy4hfZlDgQT
Flight distance : 325640 ft
Turkey
Hi, it seems here that I'm suffering from the same issue. I'm not able to adjust the vision well.
I face something like this image. could you please advise !
2022-10-28
Turkey
I was looking for this issue, it seems that it's familiar with some gear VR.
You may check this article
medium.com/@viarbox/getting-rid-of-double-vision-on-google-cardboard-6fa9b22da720
I hope if there is any solution for dji goggles 2
2022-10-28
HDPS
Flight distance : 44957 ft
Brazil
djiuser_axy4hfZlDgQT Posted at 10-28 11:24
solution would be ...replacement of an anatomically bad engineered product, this is hardware more than software problem. They will never replace or recall, our loss.
2022-10-29
ro_walker
Brazil
You're right it's also not comfortable to the nose, but this is still manageable in comparison with double vision!
2022-10-30
pdu
Flight distance : 155801 ft
Switzerland
Received my Pro View Combo on Tuesday and faced the exact same problem!
Asked two friends to wear and adjust the goggles and both could get one clear image, so I guess it's not a product defect but more of a me-problem. Checked with an optometrist and they said my eyes are fine, however they didn't really had a solution (nor any experience with such goggles) for the problem I presented (had my goggles with me to let the optometrist try and explained my vision by drawing it). They then suggested that I pay a visit to a specialized eye doctor, for which I got an appointment in two weeks. So, no "bind and fly" for me unfortunately. Let's hope that the problem can be resolved, I don't want to fly one-eyed.
Just to be sure: The optometrist also measured my IPD to make sure it's in the supported range. According to the Avata FAQ page, the adjustment range is 56-72mm, so I should be fine with my 60mm IPD I guess. So if anyone has the same problem, maybe that could be helpful.
2022-11-17
mmw.
Flight distance : 402927 ft
Singapore
had the same issue as OP and did the same as @pdu by asking a friend to adjust it. he was able to see 1 image at one go. However I kept seeing 2 images. Did what OP mention at first by trying to use one eye only. Thus setting the focus of the right eye futher away in a bid to just use my left eye. Guess what ? 2 min into the actual flight my eyes managed to combine both image into 1. Went for my 2nd flight yesterday and my eyes seems to be able to adjust faster but they will always be 2 images at first.
2022-11-20
disassoc
Switzerland
I could also solve it by not setting it up one eye after another, but combined. As the optometrist said my eyes are good, I set both oculars to "0" and then started from there, and there it was, just one single image as it should be. Either stupid user error, or maybe not an ideal manual from the goggles by setting up one eye after the other.
2022-11-21
djiuser_AKFkrz2tajjr
Brazil
disassoc Posted at 2022-11-21 01:11
Solve my problem ….
just put both adjustments on 0  at first , than ajustes the lateral adjustment .
I
2023-5-6
djiuser_uKxuOiJ9xPco
Israel
I have issue with 2 separate images on my new DJI goggles 2.
In some cases it just merge it and I see clear good 1single picture. But in some cases I see 2 separate pictures.
What is the problem?
Thank you!
2023-5-21
DJI Tony
djiuser_uKxuOiJ9xPco Posted at 5-21 19:37
Hi there. We're sorry you're experiencing the same issues. Can you post a photo showing the issue for further checking? Thank you.
2023-5-22
Vastgoed Select
Belgium
I had the same problem and it was my fault. You start the goggles and start turning the knobs with one eye closed and then with the other eye, but you actually disrupt the view without realizing it. The answer is simple, put both sides back to position 0 and put the goggles back on. It was resolved immediately for me.
2023-7-12
