Serial Number differencece
907 1 2022-10-5
Bader Saleh
Saudi Arabia
Hi ,
I'm from Saudi Arabia and it's more restricted to export drone here .
so it need to buy it from outside contries and get the serial number from them to regester it through local avaition system .
then get permissions to pass it from local cutoms .
anyway , the serial that i got when i buy it was only on the cardboard packege out side the product.
as you know inspire 2 came in hard foam case without any detailes on it . then i found out that the serial on AC is way diffrent than what i got .
and its alreday permitted on the original serial i got earlier , so can you help me with that ????
thanks .
2022-10-5
DJI Susan
Hi there, may we know the serial numbers you got from your package for further confirmation? And now you have not received the package because the custom won't release it due to the serial number issue, is that correct? Or please let me know if I misunderstand the case, thank you.
2022-10-6
