Solar Charging Mavic 3 batteries
2038 12 2022-10-6
willard1114
I have a 100W solar panel with a USB-C PD 65W protocol charging port.   Will this charge the DJI Mavic 3 batteries, charging hub, and the DJI RC Pro Remote Controller?
2022-10-6
DJI Stephen
Hello there willard1114. Thank you for reaching out and for this inquiry. I hope that our fellow DJI Co pilots who have tried this method / process in charging these DJI Mavic 3's intelligent flight batteries can share and give out the best resolution for this issue. Thank you.
2022-10-6
JJB*
Flight distance : 12477300 ft
uh, what can go wrong?  if the output Volts and Amps are within DJI specs.....
just give it a try
cheers
JJB
2022-10-6
Geo_Drone
Flight distance : 2676129 ft
Romania
If the solar charger have also a buffer battery in order to keep the power even when sun is in shade, yes.
2022-10-7
willard1114
I found a reply from a DJI expert on this form that the DJI 65w car charger employs both PPS and PD charging protocols.  The 100W solar panel  I am interested in is on Amazon at
https://www.amazon.com/gp/product/B09V2V3V5F/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1.
I was informed by the seller of this solar panel that their 65W USB-C  port also supports both PPS and PD charging protocols.   Because both the DJI 65W car charger and the solar panel I intend to purchase use the same charging protocals, then the solar panel will most likely charge the DJI Mavic 3 Cine batteries and the controler.
I am a large format photographer who spends the entire summer and early fall in the backcountry of Colorado. I use two llamas and my backpack to port around 280 pounds of gear into the wilderness. I am hoping to document my story using both the DJI Action 2 and the DJI Mavic 3 Cine cameras. Hense my need for charging with a solar panel.
I untend to pruchase rverything in January of next year. I will post the results of the actual solar charger then.
2022-10-7
Mobilehomer
Flight distance : 18150351 ft
Make sure to purchase many batteries. There will be lots of days without adequate direct sunshine.
2022-10-7
TonyPHX
Flight distance : 11229610 ft
The answer is .... heck yes. Here is my kit when I go to the RC park.
2022-10-7
TonyPHX
Also, with four panels, I can produce more energy than I require even when charging three m3, three m2p, and three dpi fpv batteries, plus controllers, plus a tablet.  Oh and one Bose bluetooth speaker.  (Yes, I like to rock out with some music while playing with my toys.)
2022-10-7
djiuser_ezNqvabS16lC
Flight distance : 1267251 ft
TonyPHX Posted at 2022-10-7 11:30
Can u tell me what panels u have?
2023-4-8
TonyPHX
djiuser_ezNqvabS16lC Posted at 4-8 17:35
Yes, got the entire kit from Jackery.  Love it.  I have had that setup for about  a year now, and many weekends I don't even take the panels, just the generator and charge from the battery to keep flying all day.
2023-4-8
Thibaud Rebour
Did you succeed with your installation ?
2023-10-1
willard1114
Yes, I was able to charge all my devices using the USB-C fast charging port.   I ended up purchasing the DJI Mavic 3 Pro drone, DJI Osmo Action 4 camera, and the DJI Mic 2.  I  also was able to charge the DJI Intelligent Flight Batteries using the 100W charging hub and the Extreme Batteries using the Multifunctional Battery Case.
Charging times under sunny conditions were just as fast as charging from a wall socket.  If the sun dims, the the charging times may sometimes take longer, but in most cases it was just as fast as a wall outlet.  The time to charge seems to be dependent on the current that the solar panel can provide at any given time and the current that is required to charge a battery.   The batteries current charging needs seem to fluctuate considerable and in most cases it is much smaller than what a 65w or 100W is charger is cable of producing. Current reductions from the solar panel did not appear to have any detrimental effects on the batteries or charging equipment.
I did modify the solar panel.  I replaced the heavy metal stands that came with the solar panel and replaced them with two modifies tent poles. The tent poles were much lighter and did a much better job of keeping the panel stretch tight and flat than the metal stands. You can adjust the angle of the panel to the sun by adjusting the intersection of the tent poles.
I have attached some pics from the document I wrote about using solar equipment.
Hope this helps, Stephen
4-23 11:03
willard1114
Thibaud Rebour Posted at 2023-10-1 06:13
They do not make the one I have anymore.   The one I have is fabric based and folds up into a nice small package,  In any case, you want to make sure the it support a USB-c PD 65W fast charging port.
4-23 13:08
