DJI Assistant 2 will not update or connect to Mavic 2 Pro
585 2 2022-10-7
nl215
Hello,
My Mavic 2 Pro recently notified me to connect to DJI Assistant to recalibrate the sensors after refusing to descend faster than ~.5mph.
When I run DJI A2 on my mac (11.6.8 OS) and then plug in my drone, it prompts me to start an update that seems to be for DJI A2.
After installation and entering my password into terminal, restarting my mac results in nothing.
I restart DJI A2, plug the drone in, and the loop repeats itself.
DJI A2 doesn't change from V2.0.14, and from searching around there doesn't seem to be any update after that.
I cannot do anything on DJI A2 with the drone plugged in without this update prompt appearing so I cannot recalibrate my drone.
2022-10-7
Sean-bumble-bee
Flight distance : 15997 ft
I haven't tried using the assistant 2 on a Mac with any drone but the immediate thought that comes to mind is, are you using the correct Assistant 2 ? There are many versions, I can't remember the one needed for the M2P but it's easy enough for you to google it.
2022-10-7
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to uninstall the DJI Assistant 2 software on your Mac and kindly please reinstall the version using the link below then check if the issue persists? Please keep us posted. Thank you.
https://www.dji.com/downloads/softwares/assistant-dji-2-for-mavic
2022-10-7
