30 watt charger for mini 3 pro & RC
6985 6 2022-10-7
Dou6ie
Flight distance : 8984337 ft
Hi all, looking for some advice on my new purchase of a DJI mini 3 pro and RC controller along with the combi pack.
I've noticed that there's no charging plug supplied now.
What I'm not sure of is which charging plug do I buy. I know it states a 30watt plug but if I'm charging both battery hub and remote at same time does this mean each device will charge at 15watt?
Any recommendations on what charging plug to buy would be greatly appreciated.
Dougie
2022-10-7
Meuhbat
Flight distance : 225210 ft
I have a 30w PD charger from Anker, it works very well with the batteries pack and the controller. If you want to charge both at the same time you need a dual 30w PD charger, or at least 1x30w + 1x15w for the controller as it is limited to 15W charging. But you don't need to charge both at the same time, the controller battery life is much longer than the drone, you can fly for hours without recharging it. You can use an old phone charger for the controller.
2022-10-7
Dou6ie
Thanks for this info Meuhbat as I’ve not got a clue regarding charging watts.. So the hub with 3 batteries will only need 30w to fast charge then the same charger would charge RC at 15w?
2022-10-7
Meuhbat
Yes the charger can adapt the charging power to the device, think about it as "up to 30W", there are multiple protocols supported by a PD charger to deliver different levels of power :
5V/3A, 9V/3A, 12V/2.5A, 15V/2A, 20V/1.5A PPS:3.3V-11V-3A 30W(Max)
2022-10-7
Dou6ie
Thanks all as I now understand  which charger I now need to purchase. Thanks again for all your help.
2022-10-7
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Hope that you could get the best recommendation from our fellow DJI Pilots here. In addition, you can use your own USB-C power adapter. It is recommended to use the DJI 30W USB-C Charger that is available on our store website or other USB Power Delivery chargers. Thank you for your valued support.
2022-10-8
Dou6ie
Hi thanks for your help. All sorted now thanks to very helpful members.
Great forum and always learning .
2022-10-9
