kikeenrique
![](https://forum44.djicdn.com/data/attachment/common/1c/common_35_usergroup_icon.png) New
I finally solved my problem by upgrading the firmware. The procedure (which I had to repeat a few times until it worked) is as follows:
* Without the battery, press and hold the power button, then connect the charger.
* Continue holding the power button and insert the battery.
* When the green LED turns off, release the power button.
* After this, a red LED should remain lit.
* Connect your device via Wi-Fi to the Tello and start the tello app. It has to show connection to the dron now.
* Proceed to install/update the firmware from the app. Even if the firmware progress seems to get stuck, wait for a few minutes (less than 5 minutes). As long as the red LED remains on, the process is still ongoing.
I did this with my iPhone, using version 1.6.6 |
