FCC mode only 7 channels?
3654 3 2022-10-9
djiuser_Pdx7n4h2qG43
Avata Pro-View purchased and based in the US but for some reason it seemed to be stuck on CE out of the box. Confirmed by going in Goggles 2 settings>Transmission>manual and 40hz is only showing 1 channel.
I then added the workaround file and got 3 ch on 40hz, however I'm only getting 7 ch on 20hz and 10hz. Should I be getting 8 ch (on 20 and 10hz) like on the DJI FPV Drone with Goggles v2?
2022-10-9
Killerbee
Flight distance : 64820 ft
I think it's different.
I got 4 channels in 40Hz mode on the FPV, and only 3 channels on the Avata.
2022-10-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The DJI Goggles 2 supports three bandwidths: 40MHz, 20MHz, and 10MHz. When the bandwidth is set to 40MHz, CH1 (one channel) is available, while there are three channels available when setting the bandwidth to 20MHz or 10MHz. In addition, the country code is mainly used to judge FCC/CE and SRRC, and we cannot judge whether it is in FCC or CE from the DJI Goggles 2 currently. Hope this helps. Thank you for your valued support.
2022-10-9
dvv
Flight distance : 443537 ft
Same issue for me. I bought drone in US and fly in US far away from any airports or cities but drone limited to only one channel and low power. Like for CE standart
2022-11-24
