to cancel RTH the wrong message is displayed!
465 3 2022-10-9
guidodg
Flight distance : 149757 ft
South Africa
Using the motion controller to cancel RTH the displayed info in the Goggles 2 says "press lock to cancel".
Should this not say "press Brake to cancel"?
   TRANSLATE with  x
    English
  TRANSLATE with
    COPY THE URL BELOW
    [url=][/url]
  [url=][/url] Back
   EMBED THE SNIPPET BELOW IN YOUR SITE [url=][/url]
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
2022-10-9
Waden
Flight distance : 192661 ft
Switzerland
During actual RTH press the brake button to Cancel
During low battery RTH Countdown press the lock button to Cancel.
If you press the brake button during RTH Countdown you just hover in place
2022-10-9
guidodg
South Africa
During low battery RTH Countdown pressing the lock button has absolutely no effect..
2022-10-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. If you are in Low battery RTH and the countdown appeared on the Goggles, you need to press ONCE the Lock button to cancel the RTH. If you are having issues with it, kindly please download the DJI Assistant 2 software on your PC/MAC, and kindly please update/refresh the firmware and check if the issue persists. You may download the software using the link below. Thank you for your understanding and support.
https://www.dji.com/downloads/so ... sumer-drones-series
2022-10-10
